Transfer Service CUCM
Occasionally, the phones are not able to transfer calls (In normal operation, the transfer works fine). So I have to restart the Cisco IP Voice Media Streaming App Service and the situation is normalized again. CUCM release 6.
Re: Transfer Service CUCM
There is no transfer service, most likely you're using MTPs and you're running out of it. You can look at the app log to confirm that.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
How I can look the app log? (CUCMver 6)
Via RTMT
java
java
I find this logs:
Machine Name: Publisher
Severity: Error
Message:  : 20510: Aug 13 09:47:34.136 UTC :  %CCM_CALLMANAGER-CALLMANAGER-3-MtpNoMoreResourcesAvailable: No more MTP resources available. Cluster ID:StandAloneCluster Node ID:Publisher
App ID: Cisco CallManager
how I can resolve this? Can you help me? I could suggest something?
The Media Termination  Point is the Publisher server. No external MTP.
MTP Publisher Status: Registered with
any suggestions ?
516
