Community Member
Transfer to hold
I am looking for a way to transfer a call to a DN and that DN automatically place that call on hold. CUCM BE 6.0
Re: Transfer to hold
Use directed call park, once you transfer to it, it's put on hold
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
True, what I am needing is to be able to park/hold a call on a Directed call park or Dn so that the user has a visible indicator the call is there and be able to press the softkey to pickup the call or take it off hold. The directed call park BLF allows me to see that there is a call parked on the slot but not hit the button to pick the call up because the directed call park feature requires a prefix to pick the call up. The shared line scenario gives the visibility and pickup features that I want just not a easy way to get the calls help to the DN's.
Community Member
[Correction]
True, what I am needing is to be able to park/hold a call on a Directed call park or Dn so that the user has a visible indicator the call is there and be able to press the softkey to pickup the call or take it off hold. The directed call park BLF allows me to see that there is a call parked on the slot but not hit the button to pick the call up because the directed call park feature requires a prefix to pick the call up. The shared line scenario gives the visibility and pickup features that I want just not a easy way to get the calls held to the DN's.
Community Member
I am looking for any help with this feature.
even if the solution is outside of CUCM, possibly scripting of some sort could meet the need. Any help is greatly appreciated.
Community Member
Did you ever figure out a way to make this work?
Community Member
Kinda, I had to loop it through contact center to do it, I might could
find the script if you are interested, but directed call park is very
similar just different mechanics to get the call "held".
Nathan Creamer | VP - Operations | The Certus Group
17200 Chenal Pkwy Ste 340 Little Rock, AR 72223
Direct/Cell: 501.235.8106 | Main: 501.291.2503 | Fax: 866.243.2979
ncreamer@mycertusgroup.com | http://www.mycertusgroup.com
On Mar 15, 2011, at 2:12 AM, "efrazee@ctgmt.com"
Community Member
Thanks for responding. I'm working on a big install at a Hospital and this is a major sticking point for the CEO/Admin dept. They want the 1 button to hold and retrieve.
Could you share the script you used? More and more I'm having to run things through UCCX to make the magic happen
Thanks in advance
Eric Frazee
Systems Engineer
CCVP
406.329.4089
efrazee@ceriumnetworks.com
Cerium Networks
Solutions for Voice Data and Video Communications
412
