12-09-2011 01:55 AM - edited 03-16-2019 08:28 AM
I a customer requirement which I need help on
They have a feature from an Avaya PABX where a user can just enter a two digit code to transfer a call into VM
Caller A rings User B
User B has CFNA to User C
User C answer and enters the two digit code and Caller A is transferred in User B`s VM
User B & C are DN`s terminating on dealing system
Avaya>>>>>> Avaya analogue ports- terminating on dealing system
I can get the same feature to work by moving User B&C from the dealing system and giving them cisco phones then ask them to use IDivert however they want to remain on the dealing system
We are mirgating them from avaya to cisco but the other system will remain
Cisco>>>>>analogue vg224>>>>DN`s terminating on another system
Cisco>>>>>qsig>>>Other system
The issue is not whether we use VG`s or we use Qsig but with the transfer to VM. They do not want to enter any further digits so I can not use the CTI RP method either. Basically they want to transfer Caller A to VM and for the transfer to keep the original User B
We are moving to Unity Coneciton but not yet
thanks
12-09-2011 02:25 AM
Since the user B is the original called number then one the call transferred to user C and user C forward the callnto VM/unity connection and user A has a vm box then it will be sent to user A vm box ?
12-09-2011 02:30 AM
User A is the extenal caller so the VM users are B and C. USer C is the last person to answer Caller A and wishes to transfer the call to User B`s VM by just tranfer +VM pilot DN
12-09-2011 02:30 AM
But the above works with CFNA however if your customer wants manual transfer then this is do able but you need to make some complex design
How many DNs need this
How they want to divert to vm
12-09-2011 02:45 AM
I know it works with CFNA but we need it to work after the call has been answered which is why I first sugested IDIVERT howwever the User B& C will not be on cisco handset but on the dealing system. I`m thinking of the forward setting on QSIG but can not work out which one- out system is production so can only do things on a weekend
12-09-2011 06:23 AM
If you gonna use unity connection you can create a call handler to b associated with user B vm box
Give the call handler a number let's say 1000
Create a cti in cucm with number 1000 and CFA to vm
Any one wants to transfer the call to user B vm box they can transfer the call to number 1000
Make sure this number routed from the other system ti cucm
Hope this help
