02-12-2012 02:46 AM - edited 03-16-2019 09:32 AM
Dear All,
i want to transfere calls on ip phone with out answering the call,there is no softkey for this in the ring in state,anyone has a suggestion .
Moath
Solved! Go to Solution.
02-12-2012 06:26 AM
Moath,
Correct, you cannot transfer a ringing phone to any destination. iDivert would allow you to transfer the call to a static destination whatever the voicemail profile assigned to the DN is set to use which typically is voicemail, but you could point to to something else as long as voicemail would not be needed on this DN.
Sorry if this does not meet your requirments, but this is the only way.
HTH,
Chris
02-12-2012 12:09 PM
Hello, I hear you, but you will never get 100% feature parity between all systems and all vendors, there are features cucm does not have and features it has that other vendors do not have, unfortunately this is one such feature
HTH,
Chris
02-12-2012 03:40 AM
where to you want to tranfer to? any destination? voicemail? (in which case you can use iDivert).
02-12-2012 06:26 AM
Moath,
HTH,
Chris
02-12-2012 11:28 AM
thank you guys,
but this is very stange in CUCM,that i can't transfer incoming calls to any other extension without answereing the calls,since most of the PBX systems have this feature ,transfering the ringing call to dynamic DN.
some people suggested the IPMA feature,i don't know if it gonna work.
02-12-2012 12:09 PM
HTH,
Chris
04-11-2013 06:37 AM
I have same issue with CUCM 8.6- SIP trunk. But we tested it successfully with older Ver of CCM and FXO.
