Transferring file to MeetingPlace Express remotely
I'm in the process of carrying out MeetingPlace Express upgrade remotely via SSH.
One of the steps is to transfer the upgrade file onto MeetingPlace Express.
The file is in the a local windows pc in the c:\mpxupgrades directory.
I get the following error when I try to transfer the file:
[root@mpxSystem upgrades]# scp c:\mpxupgrade\CUMPE_Upgrade-2.0.2.126.bin /upgrades
ssh: c: Temporary failure in name resolution
Please could somebody tell me what the correct syntax is:
IP address of pc where upgrade patch is 172.30.4.240
IP address of mpx is 172.30.200.11
Silver
Re: Transferring file to MeetingPlace Express remotely
Make sure you have Change to the root user by entering su - and enter the root password.
In the Connect to Remote Host dialog box, enter the following values:
Host Name: IP address of your Cisco Unified MeetingPlace Express system
User Name: mpxadmin
Port Number: 22
Authentication Method: leave as
The installation guide assumes you have the SCP client/daemon running on your computer.
I managed to get round the problem:
1) Log into MPX via WinSCP software - you can only login as mpxadmin; su - does not work:
You can download WinSCP here:
http://winscp.net/eng/download.php
2) SSH to MPX, switch to root then move file into a partition that has lots of space.
3) use chmod 777 on the file to change permissions.
313
