12-20-2011 12:33 PM - edited 03-16-2019 08:38 AM
I have receptionists that have their boss's extension on their phones. When someone calls that extension they want to have the option of transferring that call to the voice mail associated with that extension.
Unfortunately, the system prompts for a login instead of leaving a message. Realizing that this is an Exchange problem (probably), not a Cisco problem, has anyone else run into this? Would there be a work around?
If I transfer a call from a different extension to another voice mail extension, everything works as it should.
12-20-2011 12:40 PM
Hi Al,
We used the method listed in the link below with our "old" Octel
and then moved it to Unity Connection when we migrated so i don't see
why it wouldn't work for your setup
Cheers!
Rob
PS: if the Busy Trigger on the Bosses line is set @ 1 they could just transfer directly to his DN.
12-20-2011 04:53 PM
I already have the CTI setup described in your link. Mostly it works.
Per your suggestion, I did try the busy trigger on a line, and tested it. I got a busy signal.
So the sequence of events is:
Call extension.
Answer extension.
Transfer to 5869
Get busy.
If I:
Call extension.
Answer extension.
Transfer to *5869
I am prompted to enter my PIN.
12-21-2011 09:38 AM
Hi Al,
For the Busy Trigger portion of this to work the DN must be set to forward busy
to the VM pilot #.
Also here's a post related to our first discussion point
http://blogs.pointbridge.com/Blogs/mcgillen_matt/Pages/Post.aspx?_ID=27
Cheers!
Rob
