Transffers to VM - Busy Signal
Thiago Cella
HI people,
I´ve configured the CME and CUE, but if i configure to all calls to an extension  go to VM, the signal returns busy , could someone help me, checking the follow configs , i removed some extension configs to simplify:
CME Configs:
version 12.4
service password-encryption
service internal
hostname ROUTER_VOIP
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone BRA -3
network-clock-participate wic 0
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol cisco
sip
  session transport tcp
  no rtp send-recv
  registrar server expires max 3600 min 600
  no update-callerid
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
voice class codec 100
codec preference 2 g723r53
codec preference 3 g723r63
voice register global
mode cme
source-address 192.168.0.10 port 5060
max-dn 288
max-pool 96
timezone 17
time-format 24
hold-alert
dialplan-pattern 1 115904XXXX extension-length 4
call-forward system redirecting-expanded
voicemail 3999
tftp-path flash:
voice register dn  1
number 101
no-reg
voice register pool  1
id mac 000E.08D2.550B
number 1 dn 1
dtmf-relay rtp-nte sip-notify
voice-class codec 2
username 101 password cisco
voice translation-rule 3
rule 1 /8800/ /3901/
rule 2 /8801/ /123/
voice translation-profile Entrada-Ligacoes
translate called 3
voice-card 0
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-10 type r2-digital r2-compelled ani
cas-custom 1
  country brazil use-defaults
  metering
  category 2
  answer-signal group-b 1
interface Loopback0
description IP_CUE_Module
ip address 10.1.10.1 255.255.255.0
interface GigabitEthernet0/0
ip address 192.168.0.10 255.255.252.0
duplex auto
speed auto
interface Integrated-Service-Engine1/0
description IP_Modulo_CUE
ip unnumbered Loopback0
service-module ip address 10.1.10.2 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.1.10.1
no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.20
ip route 10.1.10.2 255.255.255.255 Integrated-Service-Engine1/0
ip http server
no ip http secure-server
ip http path flash:/gui
no cdp log mismatch duplex
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
--More--                           tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:ringtones/Vibe.raw
tftp-server flash:APPS-1.2.1.SBN
tftp-server flash:SYS-1.2.1.SBN
tftp-server flash:GUI-1.2.1.SBN
tftp-server flash:CP7921G-1.2.1.LOADS
tftp-server flash:TNUX-1.2.1.SBN
tftp-server flash:TNUXR-1.2.1.SBN
tftp-server flash:WLAN-1.2.1.SBN
tftp-server flash:apps37sccp.1-2-1-0.bin
tftp-server flash:APPSH-1.3.1.SBN
tftp-server flash:GUIH-1.3.1.SBN
tftp-server flash:CP7925G-1.3.1.LOADS
tftp-server flash:SYSH-1.3.1.SBN
tftp-server flash:TNUXH-1.3.1.SBN
tftp-server flash:WLANH-1.3.1.SBN
control-plane
voice-port 0/0/0:1
cptone BR
timeouts initial 2
timeouts interdigit 2
mgcp fax t38 ecm
dial-peer cor custom
name internal
name pstn
dial-peer cor list call-internal
member internal
dial-peer cor list call-pstn
member pstn
dial-peer voice 3 pots
corlist outgoing call-pstn
description Out Calls - Local
destination-pattern 0[2-6].......
port 0/0/0:1
dial-peer voice 2 pots
description Out Calls-DDD
translation-profile outgoing Chanada-DDD
destination-pattern 8[1-9][1-9]........
port 0/0/0:1
dial-peer voice 5 pots
translation-profile incoming Incomming Calls
incoming called-number 880.
direct-inward-dial
dial-peer voice 44 pots
destination-pattern 00T
port 0/0/0:1
prefix 0
dial-peer voice 66 pots
description Out Cell Calls
destination-pattern 0[7-9].......
port 0/0/0:1
dial-peer voice 1001 voip
corlist incoming call-internal
description CUE-Numbers
destination-pattern 39..
b2bua
voice-class codec 2
session protocol sipv2
session target ipv4:10.1.10.2
session transport udp
dtmf-relay sip-notify
dial-peer voice 1000 voip
description Extension Numbers
destination-pattern 1..
b2bua
voice-class codec 2
session target ipv4:192.168.0.10
gateway
timer receive-rtp 1200
sip-ua
telephony-service
no auto-reg-ephone
authentication credential admin cisco
em logout 0:0 0:0 0:0
max-ephones 110
max-dn 288
ip source-address 192.168.0.10 port 2000
system message XXXXX
url directories http://10.1.10.1/localdirectory
url services http://10.1.10.2/voiceview/common/login.do
url authentication http://10.1.10.1/CCMCIP/authenticate.asp
cnf-file location flash:
load 7914 S00104000000
load 7906 SCCP11.8-4-2S.loads
load 7911 SCCP11.8-4-2S.loads
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7931 SCCP31.8-4-2S.loads
load 7937 apps37sccp.1-2-1-0.bin
load 7941 SCCP41.8-4-2S.loads
load 7942 SCCP42.8-4-2S.loads
load 7945 SCCP45.8-4-2S.loads
load 7961 SCCP41.8-4-2S.loads
load 7962 SCCP42.8-4-2S.loads
load 7965 SCCP45.8-4-2S.loads
load 7970 SCCP70.8-4-2S.loads
load 7971 SCCP70.8-4-2S.loads
load 7975 SCCP75.8-4-2S.loads
time-zone 17
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 5904.... extension-length 4 extension-pattern ....
voicemail 3999
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name admin secret 5 cisco
web admin customer name adminweb password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 102 no-reg primary
type 7911
call-forward all 3999
ephone  1
mac-address 001A.4DA1.A9B8
type 7911
username "102" password 102
button  1:1
CUE CONFIGs :
clock timezone America/Sao_Paulo
hostname cue
system language preferred "pt_BR"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
log trace local enable
site name local
site-hostname 10.1.10.1
web credentials hidden
privilege ViewPrivateList create
privilege broadcast create
privilege manage-passwords create
privilege ViewHistoricalReports create
privilege ManagePrompts create
privilege local-broadcast create
privilege manage-users create
privilege ViewRealTimeReports create
privilege vm-imap create
privilege ManagePublicList create
groupname Broadcasters create
username 101 create
username 102 create
privilege ViewPrivateList description "Privilege to view private list"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege manage-passwords description "Privilege to reset user passwords"
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege ManagePublicList description "Privilege to manage public lists"
privilege ViewPrivateList operation voicemail.lists.private.view
privilege broadcast operation broadcast.remote
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege manage-passwords operation user.password
privilege manage-passwords operation user.pin
privilege manage-passwords operation system.debug
privilege ViewHistoricalReports operation report.historical.view
privilege ManagePrompts operation system.debug
privilege ManagePrompts operation prompt.modify
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege manage-users operation group.configuration
privilege manage-users operation user.configuration
privilege manage-users operation user.password
privilege manage-users operation user.mailbox
privilege manage-users operation user.pin
privilege manage-users operation user.notification
privilege manage-users operation user.remote
privilege manage-users operation system.debug
privilege ViewRealTimeReports operation report.realtime
privilege vm-imap operation voicemail.imap.user
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
groupname Administrators member rcvtelecom
groupname Broadcasters privilege broadcast
username 101 phonenumber "101"
username 102 phonenumber "102"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 2
script "aa_sbcs_v03.aef"
parameter "AfterHoursOption7" "none"
parameter "AfterHoursOption8" "none"
parameter "AfterHoursOption9" "none"
parameter "BusinessHoursOptionPound" "none"
parameter "directXferMailboxNumber" "3999"
parameter "operator" "100"
parameter "transferMaskEnabled" "false"
parameter "transferMaskPrefixDigits" "2"
parameter "DialByNameDigit" "none"
parameter "BusinessHoursOption9" "none"
parameter "BusinessHoursOption8" "none"
parameter "BusinessHoursOption7" "none"
parameter "BusinessHoursOption6" "none"
parameter "BusinessHoursOption5" "none"
parameter "BusinessHoursOption4" "none"
parameter "BusinessHoursOption3" "171"
parameter "BusinessHoursOption2" "130"
parameter "BusinessHoursOption1" "none"
parameter "extensionLength" "3"
parameter "BusinessHoursOption0" "none"
parameter "BusinessHourMenuPrompt" "Ura.wav"
parameter "AfterHoursMenuPrompt" "Ura.wav"
parameter "AfterHoursOptionPound" "none"
parameter "AfterHoursOptionStar" "none"
parameter "BusinessHoursOptionStar" "none"
parameter "allowExternalTransfers" "false"
parameter "maxRetry" "1"
parameter "AfterHoursOption0" "none"
parameter "AfterHoursOption1" "none"
parameter "AfterHoursOption2" "130"
parameter "AfterHoursOption3" "171"
parameter "DialByExtensionAnytime" "true"
parameter "AfterHoursOption4" "none"
parameter "AfterHoursOption5" "none"
parameter "Schedule" "systemschedule"
parameter "AfterHoursOption6" "none"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 2
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "334"
parameter "strMWI_ON_DN" "333"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 2
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 2
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
end reporting
ccn subsystem email
end subsystem
ccn subsystem fax
end subsystem
ccn subsystem sip
gateway address "10.1.10.1"
mwi sip outcall sub-notify
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 3901
application "autoattendant"
enabled
maxsessions 2
end trigger
ccn trigger sip phonenumber 3902
application "promptmgmt"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 3999
application "voicemail"
enabled
maxsessions 2
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail mailbox owner "101" size 7200
description "101 mailbox"
no fax enable
end mailbox
voicemail mailbox owner "102" size 7200
description "102 mailbox"
no fax enable
end mailbox
Hmm ok try 2 things. 1) Remove the dialplan pattern command under the telephony service I am suspecting the 3999 is getting changed to the full 59043999 and see if that works
2) also remove the cor on this dial peer
*Nov 20 18:45:30.995: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=135
*Nov 20 18:45:30.995: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=135, Called Number=135, Calling Number=1143514725, Calling DN=235789812 Calling Id=23780,
Redirect Number=3999, Redirect Reason=15
*Nov 20 18:45:30.995: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
This tells me that 135 got triggered and has redirected the call to 3999 so I think the dialplan pattern is the one screwing it up. If this doesn’t work then I will have to give you some more detail debugs to see what is the number it is trying to match that its getting a failure
Cheers
11 Replies 11
Jorge Armijo M
Hello Thiago,
Can you please debug the ccsip messages and capture the output? For a non working transfer to voicemail call.
Also what CUE version is currently running?
Chris Deren
Thiago,
Your dial-peer 1001 references voice-class codec 2, but I do not see that defied, can you either reference class 1, or hard code g711 codec to see if that fixes it?
Chris
auppal
you dont have an incoming dial-peer if it hits 0 the call will fail
Thnx
Thiago Cella
Friends, first thanks.
Jorge Armijo
Im running 7.0 version, follow the debug ;
I forced the codec g711, but didnt work ;
I didnt understand, why i need an incomming dial-peer?
Follow the debug, in this test i called to extension 135 configured with call-forward all 3999, but always return with signal busy :
*Nov 20 15:45:09.260: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE  sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA116D9 Remote-Party-ID:  <1143514725>;party=calling;screen=no;privacy=off  From: <1143514725>;tag=D68A6EC-982 To:  <3901> Date: Sun, 20 Nov 2011 15:45:09 GMT Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 Supported:  100rel,timer,resource-priority,replaces,sdp-anat Min-SE:  1800  Cisco-Guid: 1976801949-314905057-3164309887-1066528775 User-Agent:  Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK,  PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE  Max-Forwards: 70 Timestamp: 1321803909 Contact:  <1143514725> Call-Info:  <10.1.10.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"  Expires: 180 Allow-Events: telephone-event Content-Type:  application/sdp Content-Disposition: session;handling=required  Content-Length: 206  v=0 o=CiscoSystemsSIP-GW-UserAgent 5427 1063 IN IP4  10.1.10.1 s=SIP Call c=IN IP4 10.1.10.1 t=0 0 m=audio 17354 RTP/AVP 0  19 c=IN IP4 10.1.10.1 a=rtpmap:0 PCMU/8000 a=rtpmap:19 CN/8000  a=ptime:20
*Nov 20 15:45:09.264: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0  100 Trying Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKCA116D9 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 101 INVITE  Content-Length: 0 Timestamp: 1321803909 Contact:  <3901>
*Nov 20 15:45:09.272: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA116D9 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 101 INVITE  Content-Length: 0 Contact: <3901>
*Nov 20 15:45:09.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA116D9 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 101 INVITE  Content-Length: 172 Contact: <3901>  Content-Type: application/sdp Call-Info:  <10.1.10.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"  Allow-Events: telephone-event  v=0  o=CiscoSystemsSIP-Workflow-App-UserAgent 2235 2235 IN IP4 10.1.10.2  s=SIP Call c=IN IP4 10.1.10.2 t=0 0 m=audio 16910 RTP/AVP 0 a=rtpmap:0  pcmu/8000 a=ptime:20
*Nov 20 15:45:09.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA21369 From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Date: Sun, 20 Nov 2011  15:45:09 GMT Call-ID: 75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1  Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event  Content-Length: 0
*Nov 20 15:45:13.828: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sending: Binary Message Body
*Nov 20 15:45:13.828: Content-Type: audio/telephone-event 01 00 07 D0
*Nov 20 15:45:13.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA31AAB From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 102 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:13 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4   . P
*Nov 20 15:45:13.832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA31AAB To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 102 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:13.900: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*Nov 20 15:45:13.900: Content-Type: audio/telephone-event 01 80 00 6B
*Nov 20 15:45:13.900: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA425A From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 103 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:13 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4    .k
*Nov 20 15:45:13.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA425A To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 103 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:14.288: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*Nov 20 15:45:14.288: Content-Type: audio/telephone-event 03 00 07 D0
*Nov 20 15:45:14.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA523F3 From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 104 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:14 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4   . P
*Nov 20 15:45:14.292: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA523F3 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 104 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:14.364: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*Nov 20 15:45:14.364: Content-Type: audio/telephone-event 03 80 00 75
*Nov 20 15:45:14.368: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA61854 From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 105 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:14 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4    .u
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA61854 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 105 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:14.748: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*Nov 20 15:45:14.748: Content-Type: audio/telephone-event 05 00 07 D0
*Nov 20 15:45:14.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA715CC From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 106 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:14 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4   . P
*Nov 20 15:45:14.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA715CC To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 106 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:14.828: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
*Nov 20 15:45:14.828: Content-Type: audio/telephone-event 05 80 00 73
*Nov 20 15:45:14.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:3901@10.1.10.2:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA82195 From:  <1143514725>;tag=D68A6EC-982 To:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 107 NOTIFY  Max-Forwards: 70 Date: Sun, 20 Nov 2011 15:45:14 GMT User-Agent:  Cisco-SIPGateway/IOS-12.x Event: telephone-event Subscription-State:  active Contact: <10.1.10.1:5060> Content-Type:  audio/telephone-event Content-Length: 4    .s
*Nov 20 15:45:14.832: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok Via: SIP/2.0/UDP  10.1.10.1:5060;branch=z9hG4bKCA82195 To:  <3901>;tag=cuee112884d From:  <1143514725>;tag=D68A6EC-982 Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 107 NOTIFY  Content-Length: 0 Allow-Events: refer Allow-Events: telephone-event  Allow-Events: message-summary
*Nov 20 15:45:20.620: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:10.1.10.1:5060 SIP/2.0 Via: SIP/2.0/UDP  10.1.10.2:5060;branch=z9hG4bKQx4KezWD67zxVPN4sAhRHQ~~219 Max-Forwards:  70 To: <1143514725>;tag=D68A6EC-982 From:  <3901>;tag=cuee112884d Call-ID:  75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1 CSeq: 1 BYE  Content-Length: 0 Contact: <3901> Also:  <135>
Sent:
SIP/2.0 200 OK Via: SIP/2.0/UDP  10.1.10.2:5060;branch=z9hG4bKQx4KezWD67zxVPN4sAhRHQ~~219 From:  <3901>;tag=cuee112884d To:  <1143514725>;tag=D68A6EC-982 Date: Sun, 20 Nov 2011  15:45:20 GMT Call-ID: 75D56F15-12C511E1-BCA0897F-3F91F007@10.1.10.1  Server: Cisco-SIPGateway/IOS-12.x CSeq: 1 BYE Content-Length: 0
It seems you are calling AA and then transfering to the extension. Can youpaste the following debug
deb voip ccapi def
deb ccsip messages
Thnx
You are correct, when i call to business, the call goes to AA, and for example i disk to extension 135 (configured with
call-forward all 3999 ) when the AA transfer to extension 135 the signal returns busy, but should return a voice saying that "there is no maibox to this number"
Follow the  deb voip ccapi def:
*Nov 20 18:45:12.879: //-1/9D4AE7478031/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=1143514725
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=8800
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov 20 18:45:12.879: //-1/9D4AE7478031/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48153788, Call Info(
   Calling Number=1143514725,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8800(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   Sub Calling(TON=Subscriber, NPI=Private, Data=Z GC 4, Length=71)
   Sub Called(TON=Subscriber, NPI=Unknown, Data=Lq GC \, Length=52)
*Nov 20 18:45:12.879: //-1/9D4AE7478031/CCAPI/ccCheckClipClir:
   In: Calling Number=1143514725(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=1143514725(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Nov 20 18:45:12.879: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 20 18:45:12.879: :cc_get_feature_vsa malloc success
*Nov 20 18:45:12.879:  cc_get_feature_vsa count is 1
*Nov 20 18:45:12.879: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232337072,feature_id:6853
*Nov 20 18:45:12.879: //23780/9D4AE7478031/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1143514725(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=8800(TON=Unknown, NPI=Unknown))
*Nov 20 18:45:12.883: //23780/9D4AE7478031/CCAPI/cc_process_call_setup_ind:
   Event=0x47C330D0
*Nov 20 18:45:12.883: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8800
*Nov 20 18:45:12.887: //23780/9D4AE7478031/CCAPI/ccCallSetContext:
   Context=0x4648BF8C
*Nov 20 18:45:12.887: //23780/9D4AE7478031/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 23780 with tag 4 to app "_ManagedAppProcess_Default"
*Nov 20 18:45:12.887: //23780/9D4AE7478031/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Nov 20 18:45:12.891: //23780/9D4AE7478031/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1001, Params=0x49798BC4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 20 18:45:12.891: //23780/9D4AE7478031/CCAPI/ccCheckClipClir:
   Destination Pattern=39.., Called Number=3901, Digit Strip=FALSE
   Called Number=3901(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=9D4AE747-12DE-11E1-8031-897F3F91F007, Outgoing Dial-peer=1001
*Nov 20 18:45:12.891: //23780/9D4AE7478031/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3901
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Nov 20 18:45:12.891: //23780/9D4AE7478031/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4796CC04, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=1143514725,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3901(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Nov 20 18:45:12.895: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 20 18:45:12.895: :cc_get_feature_vsa malloc success
*Nov 20 18:45:12.895:  cc_get_feature_vsa count is 2
*Nov 20 18:45:12.895: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336848,feature_id:6854
*Nov 20 18:45:12.895: //23781/9D4AE7478031/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Nov 20 18:45:12.895: //23781/9D4AE7478031/CCAPI/ccCallSetContext:
   Context=0x49798B74
*Nov 20 18:45:12.895: //23780/9D4AE7478031/CCAPI/ccSaveDialpeerTag:
*Nov 20 18:45:12.895: //23781/9D4AE7478031/CCAPI/cc_api_call_proceeding:
   Interface=0x4796CC04, Progress Indication=NULL(0)
*Nov 20 18:45:12.911: //23781/9D4AE7478031/CCAPI/cc_api_call_alert:
   Interface=0x4796CC04, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Nov 20 18:45:12.911: //23780/9D4AE7478031/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Nov 20 18:45:12.923: //23781/9D4AE7478031/CCAPI/cc_api_call_connected:
   Interface=0x4796CC04, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Nov 20 18:45:12.923: //23780/9D4AE7478031/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=23780
*Nov 20 18:45:12.923: //23780/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x495CF624, callID1=0x5CE4, callID2=0x5CE5, tag=0x0)
   (confID=0x495CF624, callID1=0x5CE4, gcid=9D4AE747-12DE11E1-8031897F-3F91F007, tag=0x0)
*Nov 20 18:45:12.923: //23781/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x495CF624, callID2=0x5CE5, gcid=9D4AE747-12DE11E1-8031897F-3F91F007, tag=0x0)
*Nov 20 18:45:12.923: //23780/9D4AE7478031/CCAPI/ccConferenceCreate:
   Conference Id=0x495CF624, Call Id1=23780, Call Id2=23781, Tag=0x0
*Nov 20 18:45:12.923: //23780/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x615, Source Interface=0x48153788, Source Call Id=23780,
   Destination Call Id=23781, Disposition=0x0, Tag=0xFFFFFFFF
*Nov 20 18:45:12.923: //23781/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 20 18:45:12.923: cc_api_get_xcode_stream : 4534
*Nov 20 18:45:12.923: //23781/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x615, Source Interface=0x4796CC04, Source Call Id=23781,
   Destination Call Id=23780, Disposition=0x0, Tag=0x0
*Nov 20 18:45:12.927: //23780/9D4AE7478031/CCAPI/cc_generic_bridge_done:
*Nov 20 18:45:12.927: //23780/9D4AE7478031/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x615, Destination Call Id=23781)
*Nov 20 18:45:12.927: //23781/9D4AE7478031/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x615, Destination Call Id=23780)
*Nov 20 18:45:12.927: //23780/9D4AE7478031/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4796CC04, Destination Call Id=23781, Source Call Id=23780,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Nov 20 18:45:12.927: //23781/9D4AE7478031/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48153788, Destination Call Id=23780, Source Call Id=23781,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Nov 20 18:45:12.927: //23781/9D4AE7478031/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=901)
*Nov 20 18:45:12.927: //23780/9D4AE7478031/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x615, Call Id1=23780, Call Id2=23781
*Nov 20 18:45:12.927: //23780/9D4AE7478031/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Nov 20 18:45:14.119: //23780/9D4AE7478031/CCAPI/cc_api_caps_ack:
*Nov 20 18:45:14.119: //23780/9D4AE7478031/CCAPI/cc_api_voice_mode_event:
   Call Id=23780
   Call Entry(Context=0x4648BF8C)
*Nov 20 18:45:22.779: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x5CE5
*Nov 20 18:45:22.779: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
*Nov 20 18:45:22.859: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*Nov 20 18:45:22.859: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
*Nov 20 18:45:23.639: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 3 to dstCallId 0x5CE5
*Nov 20 18:45:23.639: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
*Nov 20 18:45:23.719: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*Nov 20 18:45:23.719: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
*Nov 20 18:45:25.107: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 5 to dstCallId 0x5CE5
*Nov 20 18:45:25.107: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
*Nov 20 18:45:25.187: //23780/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
*Nov 20 18:45:25.191: //23780/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
*Nov 20 18:45:30.983: //23780/9D4AE7478031/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=23780
*Nov 20 18:45:30.983: //23781/9D4AE7478031/CCAPI/cc_api_call_facility:
   Interface=0x4796CC04, Call Id=23781
*Nov 20 18:45:30.987: //23781/9D4AE7478031/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
*Nov 20 18:45:30.987: //23780/9D4AE7478031/CCAPI/ccConferenceDestroy:
   Conference Id=0x615, Tag=0x0
*Nov 20 18:45:30.987: //23780/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=23781, Disposition=0x0, Tag=0x0
*Nov 20 18:45:30.987: //23781/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Nov 20 18:45:30.987: //23780/9D4AE7478031/CCAPI/cc_generic_bridge_done:
*Nov 20 18:45:30.987: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 20 18:45:30.987: :cc_get_feature_vsa malloc success
*Nov 20 18:45:30.987:  cc_get_feature_vsa count is 3
*Nov 20 18:45:30.987: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336624,feature_id:6855
*Nov 20 18:45:30.987: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Nov 20 18:45:30.987:  feature_vsa is 4973F7C8,featname is 0
*Nov 20 18:45:30.987:  cc_get_feature_vsa count is 4
*Nov 20 18:45:30.987: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336400,feature_id:6856
*Nov 20 18:45:30.987: : Generating new featurevsa,inserting it
*Nov 20 18:45:30.987:  feature call forward featname is 4
*Nov 20 18:45:30.987:  feature_vsa is 4973F8A8,featname is 0
*Nov 20 18:45:30.987:  cc_get_feature_vsa count is 5
*Nov 20 18:45:30.987: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336176,feature_id:6857
*Nov 20 18:45:30.987: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 20 18:45:30.987: :cc_free_feature_vsa freeing 4973F6E8
*Nov 20 18:45:30.987:  vsacount in free is 4
*Nov 20 18:45:30.991: //23780/9D4AE7478031/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
*Nov 20 18:45:30.991: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 20 18:45:30.991: :cc_get_feature_vsa malloc success
*Nov 20 18:45:30.991:  cc_get_feature_vsa count is 5
*Nov 20 18:45:30.991: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336624,feature_id:6858
*Nov 20 18:45:30.991: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Nov 20 18:45:30.991: : updating existing feature vsa
*Nov 20 18:45:30.991:  feature call forward featname is 4
*Nov 20 18:45:30.991: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 20 18:45:30.991: :cc_free_feature_vsa freeing 4973F6E8
*Nov 20 18:45:30.991:  vsacount in free is 4
*Nov 20 18:45:30.995: :cc_get_feature_vsa malloc success
*Nov 20 18:45:30.995:  cc_get_feature_vsa count is 5
*Nov 20 18:45:30.995: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232336624,feature_id:6859
*Nov 20 18:45:30.995: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Nov 20 18:45:30.995:  feature_vsa is 4973F528,featname is 4
*Nov 20 18:45:30.995:  feature_vsa is 4973F8A8,featname is 0
*Nov 20 18:45:30.995:  cc_get_feature_vsa count is 6
*Nov 20 18:45:30.995: :FEATURE_VSA attributes are: feature_name:0,feature_time:1232335952,feature_id:6860
*Nov 20 18:45:30.995: : Generating new featurevsa,inserting it
*Nov 20 18:45:30.995:  feature call forward featname is 1
*Nov 20 18:45:30.995: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 20 18:45:30.995: :cc_free_feature_vsa freeing 4973F6E8
*Nov 20 18:45:30.995:  vsacount in free is 5
*Nov 20 18:45:30.999: //23781/9D4AE7478031/CCAPI/ccCallFacility:
   Call Id=23781
*Nov 20 18:45:30.999: //23781/9D4AE7478031/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Nov 20 18:45:30.999: //23780/9D4AE7478031/CCAPI/ccCallDisconnect:
*Nov 20 18:45:30.999: //23780/9D4AE7478031/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Nov 20 18:45:31.011: //23781/9D4AE7478031/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4796CC04, Tag=0x0, Call Id=23781,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Nov 20 18:45:31.011: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 20 18:45:31.011: :cc_free_feature_vsa freeing 4973F608
*Nov 20 18:45:31.011:  vsacount in free is 4
*Nov 20 18:45:31.011:  vsacount in free is 3
*Nov 20 18:45:31.979: //23780/9D4AE7478031/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48153788, Tag=0x0, Call Id=23780,
*Nov 20 18:45:31.979: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 20 18:45:31.979: :cc_free_feature_vsa freeing 4973F448
*Nov 20 18:45:31.979:  vsacount in free is 2
*Nov 20 18:45:31.979:  vsacount in free is 1
*Nov 20 18:45:31.979:  vsacount in free is 0
The call is failing because there is no route for 135.Can you check if you get any result for sh dialplan num 135. And can you remove the corlist on the 1... dial peer to see if that fixes it.
Ankur
I removed the corlist, but no sucess.
Follow the show dialplan num 135 :
Macro Exp.: 135
VoiceEncapPeer20044
    peer type = voice, system default peer = FALSE, information type = voice,
    description = `',
    tag = 20044, destination-pattern = `135$',
    voice reg type = 0, corresponding tag = 0,
    allow watch = FALSE
    answer-address = `', preference=0,
    CLID Restriction = None
    CLID Network Number = `'
    CLID Second Number sent
    CLID Override RDNIS = disabled,
    rtp-ssrc mux = system
    source carrier-id = `',    target carrier-id = `',
    source trunk-group-label = `',    target trunk-group-label = `',
    numbering Type = `unknown'
    group = 20044, Admin state is up, Operation state is up,
    incoming called-number = `', connections/maximum = 0/unlimited,
    DTMF Relay = disabled,
    URI classes:
        Destination =
    huntstop = enabled,
    in bound application associated: 'DEFAULT'
    out bound application associated: ''
    dnis-map =
    permission :both
    incoming COR list:maximum capability
    outgoing COR list:minimum requirement
    Translation profile (Incoming):
    Translation profile (Outgoing):
    incoming call blocking:
    translation-profile = `'
    disconnect-cause = `no-service'
    advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
    mailbox selection policy: none
    type = pots, prefix = `',
    forward-digits 0
    session-target = `', voice-port = `50/0/74',
    direct-inward-dial = disabled,
    digit_strip = enabled,
    register E.164 number with H323 GK and/or SIP Registrar = TRUE
    fax rate = system,   payload size =  20 bytes
    supported-language = ''
    preemption level = `routine'
--More--                               bandwidth:
        maximum = 64 KBits/sec, minimum = 64 KBits/sec
    voice class called-number:
        inbound = `', outbound = `'
    dial tone generation after remote onhook = enabled
    mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
    Time elapsed since last clearing of voice call statistics never
    Connect Time = 0, Charged Units = 0,
    Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
    Accepted Calls = 0, Refused Calls = 0,
    Last Disconnect Cause is "",
    Last Disconnect Text is "",
    Last Setup Time = 0.
    Last Disconnect Time = 0.
Matched: 135   Digits: 4
Target:
VoiceOverIpPeer1000
    description = `Extension Numbers',
    tag = 1000, destination-pattern = `1..',
    allow watch = FALSE
    group = 1000, Admin state is up, Operation state is up,
    DTMF Relay = enabled,
    modem transport = system,
    URI classes:
        Incoming (Request) =
        Incoming (To) =
        Incoming (From) =
        Destination =
    huntstop = disabled,
--More--                               dnis-map =
    permission :both
    type = voip, session-target = `ipv4:192.168.0.10',
    technology prefix:
    settle-call = disabled
    ip media DSCP = ef, ip media rsvp-pass DSCP = ef
    ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
    ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
    ip video rsvp-fail DSCP = af41,
    ip defending Priority = 0, ip preemption priority = 0
    ip policy locator voice:
    ip policy locator video:
    UDP checksum = disabled,
    session-protocol = sipv2, session-transport = tcp,
    req-qos = best-effort, acc-qos = best-effort,
    req-qos video = best-effort, acc-qos video = best-effort,
    req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
    req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
    dtmf-relay = sip-notify,
    RTP dynamic payload type values: NTE = 101
    Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
           CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
           A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, lmr_tone=0, nte_tone=0
           h263+=118, h264=119
           G726r16 using static payload
           G726r24 using static payload
    RTP comfort noise payload type = 19
    fax rate = voice,   payload size =  20 bytes
    fax protocol = system
    fax-relay ecm enable
    Fax Relay ans enabled
    Fax Relay SG3-to-G3 Enabled (by system configuration)
    fax NSF = 0xAD0051 (default)
    voice-class codec = 2
    codec = g729r8,   payload size =  20 bytes,
--More--                               video codec = None
    voice class codec = 2
    voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
    voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
    voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
    voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
    text relay = disabled
    Media Setting = forking (disabled) flow-through (global)
    Expect factor = 10, Icpif = 20,
    Playout Mode is set to adaptive,
    Initial 60 ms, Max 1000 ms
    Playout-delay Minimum mode is set to default, value 40 ms
    Fax nominal 300 ms
    Max Redirects = 1, signaling-type = cas,
    VAD = enabled, Poor QOV Trap = disabled,
    Source Interface = NONE
    voice class sip url = system,
    voice class sip rel1xx = system,
    tvoice class sip outbound-proxy = system,
    voice class sip asserted-id = system,
    voice class sip privacy = system,
    voice class sip e911 = system,
    voice class sip history-info = system,
    voice class sip anat = system,
    voice class sip g729 annexb-all = system,
    voice class sip early-offer forced = system,
    voice class sip negotiate cisco = system,
    voice class sip authenticate redirecting-number = system,
    redirect ip2ip = disabled
    local peer = false
    probe disabled,
    Secure RTP: system (use the global setting)
    voice class perm tag = `'
    Connect Time = 13197, Charged Units = 0,
    Successful Calls = 24, Failed Calls = 33, Incomplete Calls = 4
    Accepted Calls = 45, Refused Calls = 8,
    Last Disconnect Cause is "10  ",
    Last Disconnect Text is "normal call clearing (16)",
    Last Setup Time = 21741300.
    Last Disconnect Time = 10679401.
Matched: 135   Digits: 1
Target: ipv4:192.168.0.10
ROUTER_VOIP#
Cheers
TKSSS!!
Your first suggestion worked, when i removed the dialplan in telephony-service the transfer to VM worked: :
telephony-service
no dialplan-pattern 1 5904.... extension-length 4 extension-pattern ....
Why do you suspect that? And what was the function of this command : dialplan-pattern 1 5904.... extension-length 4 extension-pattern ....
Again, TKSSS!!
This is to expand all 4 digit to the full DID numbers so callers can have the full DID’s as there extension and telco can still provide 4 digits to route the call. It becomes a hassle in this case where every 4 digit gets converted to 8 digits in your case 59043999 so if you want this to work with the dialplan pattern create another dial peer like this
Dial-peer voice xxx
Destination-pattern 59043999
Point it to CUE
Translation-profile outgoing outgo
Translation-pattern rule 89
Rule 1 /3999\(.*\)/ /\1/
Translation profile outgo
Translate called 89
This will remove the 5904 and simply send 3999 to CUE and the call should still work
Cheers
Ankur Uppal
CCIE Voice #25875
Network Consulting Engineer
