Transform Mask
Hi All,
I would like to do Transform Mask with one number to all unknown outgoing calls.
OR
I would like to display the unknown numner for all outgoing calls.
Is it possible in CCM 4.0?
Gold
Re: Transform Mask
If you want to display one single number for all Outgoing calls, you can configure the same on the Gateway page. Once this is done, all calls made from that Gateway should display the same number.
Hope this helps
Re: Transform Mask
Now I am displaying the number registered DID numbers with PSTN.
Thing is like this, so of the users are forwarding the calls to their mobile, for this to work I need to configure each user mobile numbers and a common mask number in routing list.
But I really dont want to enter each users mobile numbers in routing list. I want a common routing list which will be used for unknown numbers as use our registered mask number to transfer calls to mobile phones.
OR
Is it possible to display the forwarded number itself, insted of mask number?
92
