Transformation pattern
How can I use transformation pattern in CUCM 6.1.2 ?
1 ACCEPTED SOLUTION
Re: Transformation pattern
you can read an example here:
Dial Plan
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Dial Plan
java
java
272
