04-14-2009 03:25 PM - edited 03-15-2019 05:28 PM
Hi All,
I am trying to translate one DID to CTI RP for incoming call to send the call to Attendant Console. I can dial CTI RP number internally and it works fine, but when I dial that DID from my cell phone, I am receiving ring back tone and CTI RP never dialed.
Also I am sure Translation pattern is working fine because when DID translated to the extension, that extension rings.
any suggestion would be very appreciated.
thanks
Alex
04-14-2009 05:20 PM
Does the CSS assigned to the TP list the Partition of the cti route point?
Chris
04-14-2009 05:21 PM
have you checked the CSS from the translation pattern??
maybe it can reach the phone but not the CTI RP
maybe another thing in your dial plan that could match that?
java
if this helps, please rate
