12-09-2013 07:53 AM - edited 03-16-2019 08:46 PM
internal extenson is 53XX-55XX and external line is 3670100-3670350,how can I configure translation to make PSTN Directly call internal extensions ?The Router is 2911 and line is E1.
thx!
12-09-2013 08:16 AM
Start by mentioning the call control agent and version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-09-2013 08:28 AM
Hello Fog,
You will need a translation rule, it pretty simple
if you have an H323 VGW, apply this:
first of all, you need to make incoming phone call and run " debug isdn q931" on the VGW, make sure you " term mon" the logs.
- you only can make this DID to only 250 extention as you have only 250 number, you have only 5300 to 5550
- check the number sent by Teleco. " let's say it's the last three digits 100, 101, 1xx, 2xx, and 3xx"
- at the global configuration mode do the following:
translation-rule 1
rule 1 /1\(..\)/ /53\1/
rule 2 /2\(..\)/ /54\1/
rule 3 /3\(..\)/ /55\1/
exit
translation profile voice DID
translate called 1
- Under the E1 port
voice-port 0/0/0:15
translation-profile incoming DID
if Telecom sends the full number, so you need to use this translation rule
rule 1 /36701\(..\)/ /53\1/
rule 2 /36702\(..\)/ /54\1/
rule 3 /36703\(..\)/ /55\1/
please check that and let me know.
Mohamed Helmy
12-09-2013 08:43 AM
so sorry,the E1 line is r2
12-09-2013 09:08 AM
Hello Fog,
it doesn't matter, just give it a try
Mohamed Helmy
12-19-2013 05:42 AM
Hello Fog,
please keep me updated
Mohamed Helmy
