translate external line to internal extension
internal extenson is 53XX-55XX and external line  is 3670100-3670350,how can I configure translation to make PSTN Directly call internal extensions ?The Router is 2911 and line is E1.
thx!
Everyone's tags (5)
Start by mentioning the call control agent and version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: translate external line to internal extension
Hello Fog,
You will need a translation rule, it pretty simple
if you have an H323 VGW, apply this:
first of all, you need to make incoming phone call and run " debug isdn q931" on the VGW, make sure you " term mon" the logs.
- you only can make this DID to only 250 extention as you have only 250 number, you have only 5300 to 5550
- check the number sent by Teleco. " let's say it's the last three digits 100, 101, 1xx, 2xx, and 3xx"
- at the global configuration mode do the following:
translation-rule 1
rule 1 /1\(..\)/ /53\1/
rule 2 /2\(..\)/ /54\1/
rule 3 /3\(..\)/ /55\1/
exit
translation profile voice DID
translate called 1
- Under the E1 port
voice-port 0/0/0:15
translation-profile incoming DID
if Telecom sends the full number, so you need to use this translation rule
rule 1 /36701\(..\)/ /53\1/
rule 2 /36702\(..\)/ /54\1/
rule 3 /36703\(..\)/ /55\1/
please check that and let me know.
Mohamed Helmy
Regards, Mohamed Helmy
so sorry,the E1 line is r2
Hello Fog,
it doesn't matter, just give it a try
Mohamed Helmy
Hello Fog,
please keep me updated
Mohamed Helmy
248
