Translate SIP-UA name to Called number
Does anyone know, how to use called number in SIP incoming calls instead of SIP-UA register name.
In my case A7302337 - authenticaion name, 7302338 - incoming called number.
But, dial-peer for unknow reason use A7302337.
See bellow.
Thanks in advance!
c2901.lawer#
c2901.lawer#
c2901.lawer#
c2901.lawer#
May 17 14:06:34: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:A7302337@89.207.91.6:5060 SIP/2.0
Via: SIP/2.0/UDP 89.207.94.24:5060;branch=z9hG4bK464550;rport
P-CGP-Redirector: a7302337@clients.cittel.ru
Record-Route: <sip:89.207.94.24:5060;lr>
Record-Route: <sip:rev.279774.dialog.cgatepro;lr>
Via: SIP/2.0/UDP 89.207.94.25;branch=z9hG4bKac2045160544
Max-Forwards: 69
From: <sip:89036223360@89.207.94.25>;tag=1c2045153887
To: <sip:7302338@89.207.94.24;user=phone>
Call-ID: 2045153175175201218930@89.207.94.25
Contact: <sip:89036223360@89.207.94.25>
CSeq: 1 INVITE
Supported: em,100rel,timer,replaces,path,early-session,resource-priority
Allow: REGISTER,OPTIONS,INVITE,ACK,CANCEL,BYE,NOTIFY,PRACK,REFER,INFO,SUBSCRIBE,UPDATE
User-Agent: Audiocodes-Sip-Gateway-Mediant 1000/v.5.20A.021.001
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 569
v=0
o=AudiocodesGW 2045145418 2045145099 IN IP4 89.207.94.25
s=Phone-Call
c=IN IP4 89.207.94.25
t=0 0
m=audio 6770 RTP/AVP 8 0 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=rtcp:6771 IN IP4 89.207.94.25
m=image 6772 udptl t38
a=T38FaxMaxBuffer:1024
a=T38FaxMaxDatagram:122
a=T38FaxRateManagement:transferredTCF
a=T38FaxUdpEC:t38UDPRedundancy
a=T38FaxVersion:0
a=T38MaxBitRate:14400
May 17 14:06:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=A7302337, Called Number=A7302337, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=A7302337
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
May 17 14:06:34: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=A7302337, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
May 17 14:06:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
May 17 14:06:34: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=89036223360, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
May 17 14:06:34: //-1/580225688208/DPM/dpAssociateIncomingPeerCore:
   Calling Number=89036223360, Called Number=A7302337, Voice-Interface=0x0,
May 17 14:06:34: //-1/580225688208/DPM/dpMatchSafModulePlugin:
May 17 14:06:34: //-1/580225688208/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=A7302337, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=A7302337, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
May 17 14:06:34: //-1/580225688208/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
   Calling Number=A7302337, Called Number=, Voice-Interface=0x0,
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
May 17 14:06:34: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=101, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=101
   Result=Success(0) after DP_MATCH_DEST
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=40002
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=103, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=103
   Result=SUCCESS(0)
     1: Dial-peer Tag=40006
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=104, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=104
   Result=SUCCESS(0)
     1: Dial-peer Tag=40004
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=105, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=105
   Result=SUCCESS(0)
     1: Dial-peer Tag=40003
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=106, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=106
   Result=SUCCESS(0)
     1: Dial-peer Tag=40001
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=107, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=107
   Result=SUCCESS(0)
     1: Dial-peer Tag=40005
May 17 14:06:34: //206/580225688208/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 89.207.94.24:5060;branch=z9hG4bK464550;rport,SIP/2.0/UDP 89.207.94.25;branch=z9hG4bKac2045160544
Date: Thu, 17 May 2012 14:06:34 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.3.T
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:7302338@89.207.94.24;user=phone>;tag=29C6FC-1848
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Received:
ACK sip:A7302337@89.207.91.6:5060 SIP/2.0
Max-Forwards: 69
CSeq: 1 ACK
Content-Length: 0
Everyone's tags (4)
1 ACCEPTED SOLUTION
Try to use a voice translation rule like this:
voice translation-rule 1
rule 1 /A7302337/ /7302338/
voice translation-profile XLATE_CALLED
translate called 1
If you want use the To header instead the SIP URI you must use the CUBE.
See this article: http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/
Regards.
translate called 1
Regards.
Thank you Daniele, SIP URI translation is right solution.
Very useful link.
1106
