Community Member
Translating ISDN Simulator Output
I am trying to translate the output of our Virtual Console ISDN simulator to identify the telephone number that is being sent out but the messages from our sim do not look right. Can anyone decipher these messages?
PRI:46:04.27 Q931-D-(0)Rx:"0802000A0504039090A21803A183831E0281836C0C21A0333132343332323331307004A1393131"
PRI:46:04.27 Q931-I-(0)SETUP("911")[2]
PRI:46:04.27 Going to connect 0:2(0,000Ah) -> 0:0(1,8001h) 3.1kHz audio
PRI:46:04.27 Q931-D-(0)Tx:"0802800A021803A98383"
PRI:46:04.27 Q931-D-(0)Tx:"080200010504039090A21803A983816C0C21A0333132343332323331307004A1393131740480393131"
PRI:46:04.38 Q931-D-(0)Rx:"08028001021803A98381"
PRI:46:04.38 Q931-I-(0)CALL PROCEEDING
PRI:46:04.38 Q931-D-(0)Tx:"0802800A02"
PRI:46:04.39 Q931-D-(0)Rx:"080280014508028191"
PRI:46:04.39 Q931-I-(0)DISCONNECT
PRI:46:04.39 Q931-D-(0)Tx:"0802800A4508028191"
PRI:46:04.48 Q931-D-(0)Rx:"0802000A7D080381E202140103"
PRI:46:04.48 Q931-I-(0)STATUS
PRI:46:04.52 Q931-D-(0)Rx:"0802000A4D"
PRI:46:04.52 Q931-I-(0)RELEASE
PRI:46:04.52 Q931-D-(0)Tx:"080200014D"
PRI:46:04.52 Q931-D-(0)Tx:"0802800A5A"
PRI:46:04.58 Q931-D-(0)Rx:"080280015A"
PRI:46:04.58 Q931-I-(0)RELEASE_COMPLETE
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Translating ISDN Simulator Output
looks to that 312 432 2310 is calling 911.
Hope this helps.
Community Member
Read Between the Threes! :)
Hope this helps.
Community Member
Yes, that is very helpful, thank you. But how can I translate the output? How is it encoded?
Community Member
Community Member
Thanks, I figured it out right before you answered. I am a bit embarrased that I didn't notice it before now. Is the number 3 a standard spacer for ISDN?
No. What you see is hexadecimal representing the string. The numbers are coded in ascii, so 30=0, 31=1, and so forth.
Thanks for the rating!
153
