03-21-2008 09:14 AM - edited 03-15-2019 09:34 AM
I planning to have 10 digit extensions in CUCM I want the users to be able to dial both 10 digit or just last 4 digits of their numbers to call each other? How can this be done, since all the translation rules refer to external calling and not internal extension to extension ?
03-21-2008 10:49 AM
You can create a translation pattern to accomplish this. Make the translation pattern 111222XXXX for example and make the called party transform mask XXXX. Make sure the translation pattern is in a partition accessible by the CSS on the internal phones.
Hope this helps. If so, please rate the post.
Brandon
03-21-2008 11:52 AM
Thanks!
03-21-2008 02:43 PM
Test
