K D
Translation in SRST mode only
Hi All,
I am using e164 numbing standard for all my directory numbers. the format is 6188237XXXX.  I am using an Translation rule for incoming call to get
translated to 618XXXXXXXX number. This part works fine. The question is, in CUCM the site uses 4 digit for site internal calling and I have achieved it using Translation pattern.  The problem is when the WAN fails all phone registers to local gateway as a 618XXXXXXXX number. So i am not sure where the 4 digit dialing can be achieved in SRST mode. I have attached relevant config for reference.  Can you please let me know whether this will work?
TP for incoming calls to get translated in to e164 format:
voice translation-rule 2
rule 1 /^088237\(....\)/ /6188237\1/
rule 2 /^88237\(....\)/ /6188237\1/
Below is for SRST short dilaing:
voice translation-rule 3
rule 1 /^96\(..\)/ /618823796\1/
The fallback config is a s below:
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 8
timeouts busy 12
ip source-address 172.24.96.3 port 2000
max-ephones 250
max-dn 350 dual-line
system message primary ** Fall-Back Mode **
transfer-pattern .T
translate called 3
date-format dd-mm-yy
Will the above config work alright.
Everyone's tags (2)
1 REPLY
There're few ways to achieve that.
1. Create voice translation-rule to match your different sites 4 digit ext, then prepend the require number to match your out-going dial-peer.
2. From the telephony-service, you may create dial-plan to expand the 4 digit internal dialing to each respective site number.
regards,
419
