Translation Pattern Change
I looking at changing my Translation patterns to complete a project. Right now, I'm using *991 that translates to 77795969 which route the call off a gateway (7779 is the gateway access code). the projec calls for over 500 new numbers to be translatted and I would like to keep everything in the *99x or *99xx range what do I need to do to expand to allow for *99xx to work?
1 REPLY
Hall of Fame Super Red
Re: Translation Pattern Change
Hi Arthur,
You would need to remove the *991 pattern and replace with *99xxx to accomodate 500 plus numbers (xxx would take you up to 1,000 possible numbers :)
Cheers!
Rob
119
