Translation Pattern CUCM 7.0 - 4 digit to external number
Hello All,
I'am trying to configure some translation patterns which translates the 4 digit dialed number to an external number. However when I dial the 4 digits I get a fast busy. the access code is (9.) and normal dialing works.Do I need route patterns without 9., to get this to work?
Jason
1 REPLY
Re: Translation Pattern CUCM 7.0 - 4 digit to external number
No, translate whatever 4 digit number you want into something that matches a valid route pattern you already have.
Just make sure to use the right CSS for TP.
java
if this helps, please rate
java
www.cisco.com/go/pdi
212
