Community Member
Translation pattern fails
Hi I have in a CUCM 8 a Translation-pattern to a internal extension, this fails and the debug shows ´Unallocated/unassigned number´
That extension is registered, and without any problem, i even test the TP with other extension, and fails again.
The call from CUCM to the remote site go through h323 trunk to a CME-SRST site.
ISDN channel are well, and outbound calls runs properly, this is the sh isdn status:
Global ISDN Switchtype = basic-net3
ISDN BRI0/0/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/0/1 interface
        dsl 1, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
And the debug isdn q931
Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x82
                Preferred, B2
        Calling Party Number i = 0x2183, '6xxxxxxxx'
                Plan:ISDN, Type:National
        Calling Party Number i = 0x0183, '6xxxxxxxx'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '91xxxxxxx'
*Aug 22 09:05:42.448: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xB4
        Channel ID i = 0x8A
                Exclusive, B2
*Aug 22 09:05:42.464: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xB4
        Cause i = 0x8081 - Unallocated/unassigned number
*Aug 22 09:05:42.620: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x34
*Aug 22 09:05:42.620: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xB4
I have other Translation-pattern to other extension but in other sites from cluster and all works fine, why this is failing?
The dial-peer are:
dial-peer voice 100 pots are (only put one for BRI)
dial-peer voice 1 pots
preference 1
destination-pattern 0T
port 0/0/0
dial-peer voice 20 pots
destination-pattern 06........
port 0/0/0
forward-digits 9
dial-peer voice 10 pots
preference 1
destination-pattern 09........
port 0/0/0
forward-digits 9
incoming called-number .
direct-inward-dial
port 0/0/0
port 0/0/0
forward-digits 9
preference 1
port 0/0/0
forward-digits 9
direct-inward-dial
port 0/0/0
Into CUCM/DNA show it runs, which could be the cause of this problem??
Thanks!!
1 ACCEPTED SOLUTION
I only see POTS DPs there, where are the VOIP DPs which are the ones you should be interested in??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
VIP Super Bronze
Re: Translation pattern fails
Ivan,
This is usually caused by a wrong CSS assigned to the translation pattern. You need to ensure that the CSS on the translation pattern has access to the devices its trying to reach. So check the CSS on it.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Hi!
No matter what extension I put in the translation-p , always fails, outbounds calls runs well, only fails inbound.
I have checked CSS but seems fine, have all partition asigned.
thanks.
VIP Super Bronze
Ok. Can you send a screen shot of your translation pattern.
This is what you should have . (random example)
Translation Pattern: XXXXXX
parttition: PT_YYYY
CSS: CSS_ZZZ
Called party transform mask: 7000XXX
1. The CSS on your gateway has acess to the Partition of the Xlation pattern
2. The CSS on your xlation pattern has access to the partiton of your called party xform mask
3. Configure your called party xform mask correctly
If you send a screen shot, called and transformed mask I am sure we can fix this
java
java
Community Member
Hi!
Finally was resolved the problem, was a dial-peer voip, the call enter in the Router, but it does not know what to do with that number because is associated a extension registered via wan in the CUCM, so in the dial-peer voice voip needed to put as destinattion-p the number of the TP.
dial-peer voice 1234 voip
session-target: ip CUCM
destination-pattern ---> the telephony number of the basic header, and the TP number.
Thanks!!!!
355
