Community Member
Translation Pattern for Diverted calls
Hi)
I'm after a bit of help with translation patterns.
We have an incomming BRI line on an H323 gateway, 5056020, that follows a translation rule
"rule 1 /^.*\(..\)/ /4581\1/" to connect to reception (it replaces 5056020 with 458120
which is the recption phone.
We have a separate PSTN line, 5056030, that is redirected by the telco to 5056020.
I need to be able to send these incomming redirected call to a different extn, 458162.
I have tried a few options such as
voice translation-rule 1       **sends calls to reception**
voice translation-rule 7    ** sends calls to Extn 458162**
rule 1 /^5056030$/ /458162/
voice translation-profile INGRESS
translate called 1
translate redirect-called 7
Whatever I do all calls go to reception, any thoughts ?
Below is debug isdn q931 for reference for a redirected call.
I am trying to work with the "redirecting num 5056030" part.
thanks.
router#
Oct 14 13:47:58 UTC: ISDN BR0/2/1 Q931: RX <- FACILITY pd = 8  callref = N/A
        Facility i = 0x91A10E02010102010C30060A01010A0101
                Protocol Profile = Remote Operations Protocol
                0xA10E02010102010C30060A01010A0101
                Component = Invoke component, Unsupported operation
        Called Party Number i = 0x81, '5056030'
                Plan:ISDN, Type:Unknown
Oct 14 13:47:58 UTC: ISDN BR0/2/1 **ERROR**: host_facility_invoke: HOST_FAC_INV: B-channel = D-channel
                call id 0xFFFF
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8  callref = 0x1E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Facility i = 0x91A1210202008002010F30180201010A0101A110A00EA10C0A0104120734383633303330
                0xA1210202008002010F30180201010A0101A110A00EA10C0A0104120734383633303330
                        Invoke Id = 128
                        Operation = Diversion Leg2
        Calling Party Number i = 0x0180, '01234 5678910'
router# i = 0x0183, '01234 5678910'
        Called Party Number i = 0x81, '5056020'
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5056030
                 reason 15 cnt 1 plan 4 type 1 pres 0
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x9E
        Channel ID i = 0x89
                Exclusive, B1
Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0x9E
router#
router#
Oct 14 13:48:06 UTC: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x1E
        Cause i = 0x8090 - Normal call clearing
translate called 1
Hi Rob,
Can you please share below things:
1). running-config
2). debug isdn q931
3). debug voice ccapi ind 2
4). debug voice translation
After that, try by modifying your voice translation-rule 1 as below
rule 1 /^.*\(20$\)/ /4581\1/
OR
rule 1 /^50560\(20$\)/ /4581\1/
OR
rule 1 /^5056020$\/ /458120/
Nishant Savalia
Regards, Nishant Savalia
Community Member
Hi Nishant,
Thanks for the reply but I am not sure how this will help, the translation rules provided surely will only affect calls to  5056020 which already works.
What I am trying to do is pick out the diverted number of 5056030 which can be seen in the above q931 debug at
"Oct 14 13:47:59 UTC: ISDN BR0/2/0 Q931: extract_redirect_orig_called_ie: IE type redirecting num 5056030"
which I need to send to extn 458162.
Sorry I am not at work for the other info at the moment
Regards, Rob
VIP Super Bronze
Rob,
Have you tried just using "translated called" instead of redirect. You need to change your translation rule to include the number...
e.g.
rule 2 /^5056030$/ /458162/
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
465
