Translation Pattern happening but can't see it in CUCM!
Am using CUCM 6.1 and at the moment whenever a user dials 9118xxx it redirects the call to 118500 however under Call Routing > Translation pattern I cannot see this rule to amend it, any ideas on what I'm missing here?
Thanks!
Re: Translation Pattern happening but can't see it in CUCM!
Look at the dial plan for matches or use DNA, there must be something else (Phone, CTI RP, etc) that's matching and might have CFA
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Ah, found it under route plan report.
Thanks!
240
