Community Member
Translation Pattern Help Required
Hi Team,
I am trying to create a translation pattern, and I am finding some difficulties. I am using H.323 gateway. I want the number 30300 to be translated to 0015126021000.
I have attached the gateway configuration. kinldy help.
Hall of Fame Super Silver
Do you want to build Translation Pattern on CallManager or translation rule on the GW?
If the second the rule should be:
voice translation-rule 1
rule 1 /^30300/ /0015126021000/
voice translation-profile DID
translate called 1
If this is static replacement, if you want to copy the last 4 digits for example you would do
rule 1 /\(^3....\)/ /00151260\1/
This would make 30300 --> 0015126030300
HTH,
Chris
So, that number are you getting and what do you want to see? Is it 08033230300 -- > 0015126021000?
If so simply do
rule 1 /^08033230300/ /0015126021000/
Chris
Community Member
HI Chris,
My full number is 08033230300. The users may call that number depending on the location. If they are calling from a landline they will dial as 33230300. If they are calling from a moblie phone they will dial as 08033230300. If they are calling from the office IP phone they will dial only 30300. So how ever they cal the call should go to 0015126021000.
So, is this inbound or outbound?  If inbound it does not matter what they dial, what matters is what your telco is presenting to you which is always going to be consistent. If you want to see what that is use "debug isdn q931".
If this is for outbound then you should have proper Translations and/or Route Patterns on CUCM and ensure these do not create overlaps.
HTH,
Chris
Community Member
Hi Chris,
Now used translation pattern in cucm and I am able to translate the number successfully. But now another problem has arised. We have two different service providers here. The call translate when using one and it doesnt happen with the other service provider. May be the issue is with the dial peer configuration. Let me check that.
Great, let us know if you need any further assistance.
HTH, please rate all helpful posts!
Chris
Community Member
Hi Chris,
Yes Chris I would require one more help. Now I went through all the h323 configuration and found that the incoming calls to one SP PRI is not happening. Unfortunately thats our primary pri.  When I try to call my IP Phone using my mobile, it says all the channels are busy. A couple of hours before those calls were happening without any problem. The calls through the other SP pri is fine including the number translation.
Please post "debug isdn q931" and "debug isdn status".
Chris
Community Member
Hi Chris,
show isdn status:
iec-v-gw-01#show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State =
MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial0/0/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
ISDN Serial0/1/0:15 interface
        dsl 2, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 2 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 1
ISDN Serial0/1/1:15 interface
        dsl 3, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 3 CCBs = 0
ISDN Serial0/2/0:15 interface
        dsl 4, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 4 CCBs = 0
ISDN Serial0/2/1:15 interface
        dsl 5, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 5 CCBs = 0
    Total Allocated ISDN CCBs = 0
debug isdn q931:
                Exclusive, Channel 24
May 11 20:38:48.450: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 8033230000
May 11 20:38:48.450: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x00FF callID = 0x80AC switch = primary-net5 interface = User
May 11 20:38:48.450: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00FF
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98388
                Exclusive, Channel 8
        Calling Party Number i = 0x0181, '8033230000'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xC1, '33230102'
                Plan:ISDN, Type:Subscriber(local)
May 11 20:38:48.486: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80FF
May 11 20:38:48.500: ISDN Se0/2/1:15 Q931: RX <- SETUP pd = 8  callref = 0x0002
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA18399
                Preferred, Channel 25
May 11 20:38:48.500: ISDN Se0/2/1:15 Q931: Received SETUP  callref = 0x8002 callID = 0x0085 switch = primary-net5 interface = User
May 11 20:38:48.500: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 8033230000
May 11 20:38:48.500: ISDN Se0/1/1:15 **ERROR**: CCPMSG_OutCall: fails with cause 0x22
May 11 20:38:48.500: ISDN Se0/2/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8002
        Channel ID i = 0xA98399
                Exclusive, Channel 25
May 11 20:38:48.500: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 8033230000
May 11 20:38:48.500: ISDN Se0/2/0:15 Q931: Sending SETUP  callref = 0x0100 callID = 0x80AE switch = primary-net5 interface = User
May 11 20:38:48.500: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0100
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98387
                Exclusive, Channel 7
May 11 20:38:48.536: ISDN Se0/2/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8100
May 11 20:38:48.550: ISDN Se0/2/1:15 Q931: RX <- SETUP pd = 8  callref = 0x0003
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA1839A
                Preferred, Channel 26
May 11 20:38:48.550: ISDN Se0/2/1:15 Q931: Received SETUP  callref = 0x8003 callID = 0x0086 switch = primary-net5 interface = User
May 11 20:38:49.227: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80FA
        Cause i = 0x80A2 - No circuit/channel available
        Progress Ind i = 0x8288 - In-band info or appropriate now available
May 11 20:38:49.227: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00FA
        Cause i = 0x82E31E - Information element not implemented
May 11 20:38:49.245: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80FA
May 11 20:38:49.245: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80FB
May 11 20:38:49.245: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80FA
May 11 20:38:49.269: ISDN Se0/2/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F8
May 11 20:38:49.269: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00FA
May 11 20:38:49.269: ISDN Se0/2/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x809E
May 11 20:38:49.269: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80FA
May 11 20:38:49.269: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F9
May 11 20:38:49.271: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F9
May 11 20:38:49.295: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F9
May 11 20:38:49.295: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F9
May 11 20:38:49.295: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F9
May 11 20:38:49.297: ISDN Se0/2/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F8
May 11 20:38:49.299: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F7
May 11 20:38:49.299: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x809C
May 11 20:38:49.299: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F8
May 11 20:38:49.315: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F8
May 11 20:38:49.327: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F8
May 11 20:38:49.327: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F8
May 11 20:38:49.327: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F7
May 11 20:38:49.329: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F6
May 11 20:38:49.329: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x809B
May 11 20:38:49.329: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F7
May 11 20:38:49.349: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F7
May 11 20:38:49.357: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F7
May 11 20:38:49.357: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F7
May 11 20:38:49.357: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F6
May 11 20:38:49.359: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F5
May 11 20:38:49.359: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x809A
May 11 20:38:49.359: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F6
May 11 20:38:49.379: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F6
May 11 20:38:49.387: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F6
May 11 20:38:49.387: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F6
May 11 20:38:49.387: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F5
May 11 20:38:49.389: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F4
May 11 20:38:49.389: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8099
May 11 20:38:49.389: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F5
May 11 20:38:49.409: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F5
May 11 20:38:49.417: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F5
May 11 20:38:49.417: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F5
May 11 20:38:49.417: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F4
May 11 20:38:49.419: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F3
May 11 20:38:49.419: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8098
May 11 20:38:49.421: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F4
May 11 20:38:49.439: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F4
May 11 20:38:49.447: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F4
May 11 20:38:49.447: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F4
May 11 20:38:49.447: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F3
May 11 20:38:49.449: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F2
May 11 20:38:49.449: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8097
May 11 20:38:49.451: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F3
May 11 20:38:49.469: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F3
May 11 20:38:49.477: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F3
May 11 20:38:49.477: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F3
May 11 20:38:49.477: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F2
May 11 20:38:49.481: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F1
May 11 20:38:49.481: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8096
May 11 20:38:49.481: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F2
May 11 20:38:49.499: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F2
May 11 20:38:49.507: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F2
May 11 20:38:49.507: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F2
May 11 20:38:49.507: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F1
May 11 20:38:49.511: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F0
May 11 20:38:49.511: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8095
May 11 20:38:49.511: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F1
May 11 20:38:49.529: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F1
May 11 20:38:49.537: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F1
May 11 20:38:49.537: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F1
May 11 20:38:49.537: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00F0
May 11 20:38:49.541: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80EF
May 11 20:38:49.541: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8094
May 11 20:38:49.541: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80F0
May 11 20:38:49.559: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F0
May 11 20:38:49.567: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00F0
May 11 20:38:49.567: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80F0
May 11 20:38:49.567: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00EF
May 11 20:38:49.571: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80EE
May 11 20:38:49.571: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8093
May 11 20:38:49.571: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80EF
May 11 20:38:49.589: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80EF
May 11 20:38:49.597: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00EF
May 11 20:38:49.597: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80EF
May 11 20:38:49.597: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00EE
May 11 20:38:49.601: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x80ED
May 11 20:38:49.601: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x8092
May 11 20:38:49.601: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x80EE
May 11 20:38:49.619: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80EE
May 11 20:38:49.627: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x00EE
May 11 20:38:49.627: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x80EE
May 11 20:38:50.157: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x808E
May 11 20:38:50.157: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8  callref = 0x00DA
May 11 20:38:50.163: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80DB
May 11 20:38:50.183: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80DA
Community Member
As Salam,
from the debugs I found that there is a hairpin call at your gateway. As the outgoing was from the port 0/2/0 and again there is an incoming from 0/2/1 and the port 0/2/1 is fwd the disconnect as No Circuit/Channels available.
Here, you need to make sure that the Service Provider's B-Channel order based on the you need to configure the gateway, If the SP is sending the call on 31st channel you need to configure "isdn bchan-number-order ascending" on your serial interface else by default it will be descending. Also make sure that you have enough DSPs (PVDMs or NM-HDVs) to support the channels for transcoding.
Mohsin Khan..
Community Member
Salam,
Yes your are correct that the hair pin calls are happening. So I had issued 'isdn bchan-number-order ascending' on serial interface 0/1/1, as it is my primary pri port. I will apply this command to rest of the serial interfaces and will let you knw. As far as d DSP's are concerened, the same scenario was working fine until yesterday where mgcp was the protocol. Yesterday i changed it to h.323. My outgoing calls r happening on the same interface but incoming r not happening on 0/1/1, 0/2/0 and 0/2/1.
Community Member
Ya i executed the 'isdn bchan-number-order ascending' still its not working.
Community Member
Hi Guys,
At last I solved it!!!
Thanks for all the valuable suggestions.
I took the translation-profile from the dial-peers and applied on the voice-ports.
Changed incoming called-number 30... to incoming called-number .
1563
