Community Member
translation pattern issue
We receive from our pstn provider 7 digits (first 3 digits are site access code to determine the site
where the ipphone is located and the last 4 digits is the extension)
that we use to route the inbound calls to ipphones.
I have created translation patters that strip of the first 3 digits and then sent the call to the 4 digit extension in the correct partition.
However when I check the config with the dialed number analyzer using the gateway option (so I can simulate inbound calls)
, I get this message : Match Result = BlockThisPattern
When I check the call flow part of the DNA output I can see it uses the correct translation pattern.
Any ideas?
Jeroen
1 ACCEPTED SOLUTION
Silver
Re: translation pattern issue
Don`t forget the TP has it` own CSS as well- could the block be this? Though the call is via the Gateway, the second part of the call is via the Translation pattern with it`s own CSS . Use the DNA again but only the analyser part and enter the CSS of the TP. If the GW is just used for PSTN you can use the significant feature so to strip the digits as they come in - this is on the actual gateway if you use MGCP
Silver
Community Member
The CSS on the translation pattern fixed the issue.
Jeroen
make sure in the translation pattren u have chosen route this pattren not block option
als make sure the TP has CSS that include internal phones partition
if helpful Rate
282
