Translation Pattern limitation
Rohith R.A
Hello Evrryone,
Is there any limitations to add the translation pattern on the Cisco Call Manager, also if there is any limitation specific to CUCM version.
I have a requirement where i need to configure approx 4000 translation patterns.
Searched the same in SRND and CUCM admin guide but have no info on this, also please let me know if adding more translation patterns to the call manager will by anyway impact the performance of the box.
Rohith
ronpatel
Level 8
Level 8
Hi ,
There are no hard numbers on how many TPs you can have.
Obviously if you do create a large number like 10K you might need to tweak the DB initialization numbers to avoid problems.
CUCM service parameter:
System Initialization Timer
Also careful design of CSS and partitions need to be taken as otherwise it might cause delay
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Agreed with Ronak here (+5), I have customer with large number of TPs used for system speed dials and no issues.
HTH,
Chris
Thanks Ronak..
