Translation pattern to convert number to pilot number
I would appreciate some help in suitable method of translating a published number for a group XXXXXXX9640 and would like this translated to a ephone-hunt group pilot number (i.e. 5002), can anyone suggest the best method?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Translation pattern to convert number to pilot number
Use either translation rule or num-exp. You did not specify how many digits you are getting from telco. For the following example lets assume it's 4.
voice translatio-rule 1
rule 1 /^9640/ /5002/
voice translation-profile 1
tranlsate called 1
dial-peer voice 1 pots
incoming called number 9640
translation-profile incoming 1
you can also apply the translation profile to voice-port.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
num-exp is slighly easier all you would need to do is:
num-exp 9640 5002
HTH, please rate helpful posts!
Chris
Hall of Fame Super Gold
you don't even need to translate, but if you have DID, likely you are translating already.
Eg:
ephone-hunt 1 sequential
pilot 5002 secondary xxxxxx9640
If were translating already on incoming, leaving the DID portion only, that would be:
pilot 5002 secondary 9640.
Hope this helps, please rate post if it does
tranlsate called 1
num-exp 9640 5002
Chris
Silver
Thanks Chris. This link helped.
I had seen it before and thought to myself, when would I ever need the 'number slice' feature....well, I just found one!
Thanks again.
154
