Community Member
Translation Pattern Usage Report
I am trying to determine if a translation pattern is still needed.  Is there a report that can be run?  Call Manager Release 6.1.  Thank you.
1 REPLY
You can try to check in CDR for the Called Party number (Original and Final) if they match the Translation pattern or the Called Party Transformed number (using Mask or Prefix).
HTH,
Jagpreet Singh Barmi
257
