03-20-2017 06:45 AM - edited 03-17-2019 09:51 AM
Team,
I am currently working on a project where i have to upload TP multiple times. When i try to upload the TP using BAT , it is only accepting tar file with name "translationpattern". But second time i cannot upload with the same name;it would overwrite. Any solution for this. As a work around i am modifying the same tar file and overwriting it again. But sometime soem one from my team has to do it. Help here!
03-20-2017 07:25 AM
I believe You are using import export window. You can give different name to tar file and upload. when your teammate is doing he can use some other name like Update-1, Update-2 etc.
I believe it will accept any name for the tar file. But the CSV file inside should have same Name.
So you and keep on changing the Tar file name.
and do rate and mark correct as applicable!!
03-21-2017 05:24 AM
Not working. I tried with different .TAR file . It is not taking.
CUCM Version:System version: 10.5.2.10000-5
03-21-2017 05:41 AM
What is the error you get can you share screen shot ?
03-21-2017 06:32 AM
No errors. It will show total entries 1, successful 1,zero errors and cannot see entries in TP
I got 42 entries, ideally it should show 42 successful
03-20-2017 07:30 AM
Your tar file can be any name. Your csv name should be translationpattern. So you can upload tar using different name (for example using versioning) but the inside csv is important.
03-21-2017 05:24 AM
01-23-2018 11:39 PM
It's old post still I am curious to know if it's resolved.
Santosh
