Translation patterns for Speed Dials & plant paging
juwaack68
Hello. We have ton of Translation Patterns that we use as Speed Dials. They are all set up as:
- Translation Pattern: *xxx. (i.e., *760.)
- Discard Digits: PreDot
- Called Party Transform Mask: 918005551212
These all work great, but now we have a need to do in-plant paging for some sites that we are migrating from Nortel to Cisco. The current (and published) in-plant paging numbers are *76, *77, etc.
If we set up a Translation Pattern as *76., with PreDot and then the Mask as an extention (that goes to the paging system), that works GREAT - but now all of the speed dials that start with *76 are broken, and they all go to the paging system.
How can we get around this, and still use the published paging numbers, while preserving the speed dial numbers?
Thanks in advance.
thomas.chen
Level 6
Level 6
If you are using Cisco callmanager you can create speed using the the document below.
and remove the translation patterns
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094765.shtml
If you are using CME try out
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807d62fa.html#wp1035279
dconstantino
Level 4
Level 4
Not sure why you are doing a pre dot since the pattern is *XXX.
For the Paging I would use the a access code like 8*76 predot
All of the speed dials were set up as translation patterns well before I started supporting this system.....
Thanks for the replies.
mschuh
the reason for this behaviour is Urgent Priority, but you can't this option disable in translation patterns. you need to configure an escape character (e.q.8) for the paging system OR the TP.
