translation patterns question
How can I cut the 1234 from the called id with translation patterns ? Can I add this translation pattern to the dial-peer ?
ex:
dial-peer voice 111 voip
     destination-pattern 1234....
     session target-ipv4:1.1.1.1
I want to cut this 1234. There is no forward-digit 4 in voip dialpeers.
Regards.
1 REPLY
Re: translation patterns question
You could try this:
voice translation-rule 10
rule 1 /^1234/ //
voice translation-profile strip1234
translate called 10
     translation-profile outgoing strip1234
translation rule 10 will strip 1234 from the beginning of the called number.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
153
