Silver
Translation Patterns- timers
I`m using TP`s to configure the cluster- all my internal calls go to the TP against a Specific Pattern and get routed correctly however there is a delay going through the TP`s - is there a setting which decreases it - by default the Urget is ticked and it is not the 302 timer- thanks
Re: Translation Patterns- timers
TP do not have IDT, there must be something else that causes the IDT on your system as after the called party is translated it's subject to DA again.
look at the route plan report for overlapping
thousands of possible options can cause some delay
java
if this helps, please rate
java
www.cisco.com/go/pdi
Silver
There are other matches based upon the resultant number however only around 7 of the possible 16 are matched due to their Partitions only being the CSS of the TP . I know that TP`s have the potential to loop around 15 x. Is this delay normal in that it is quite noticeable
try to decrease the inter digit time out
127
