translation rule for DID
techguy
Level 4
Level 4
  • 44102152 à 3152
  • 44102160 à 3160
  • 44102153 à 3153
  • 44102171 à 3171 (one can be like /^2171/ /3171/)
  • 44102128 à 3228
  • 44102101 à 3201
  • 44102130 à 3230
  • 44102194 à 3194
  • 44102104 à 3304
What can be the best (or one) translation rule for above-mentioned numbers
Since last digit is not used for the matching. It will remain intact. For example
/^441021\([5679]\)$/ /31\1/
44102152
Result would be 3152.
31 because we are adding it
5 because we are using \1
2 because it is not matched in above rule , so will remain intact.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
6 Replies 6
ronpatel
Level 8
Level 8
HI
I could not find any sequence so best can be
You can use
/^441021\([203]\)$/ /32\1/
/^44102104$/ /3304/
Ronak Patel
underlined part of translation rule will select one digit or two digit.
one digit..Also I had type mystake. Please remove $ from 1 and 2 rule.
There are total 8 digits first six are 441021 then one selected by underlined part. what about last digit
it means last digit will not be mentioned if underlined part of translation rule will select one digit.
44102152
Ronak patel
