Showing results forĀ
Search instead forĀ
Did you mean:Ā
Translation rule help DID block to Internal DN
thomuff
Level 3
Level 3
I apologize in advance  if this is a duplicate post
Here is the existing rule where any calls to this range translates to 76000
rule 15 /^21255514..$/ /076000/
I need to change this rule to where the first 6 digits are stipped  leaving the last 2 and then I add 0 and 7 at the beginning
Im thinking
rule 15 /^21255514..$/ /0714../
The DID range is 2125551400 - 2125551414
The ultimate goal is
2125551400 translate to 071400
2125551401 translate to 071401
This is a 2851 router
9 Replies 9
thomuff
Level 3
Level 3
I forgot to mention I already have other rules in place that are specific translations
For example
2125551415 translate directly to 076001
William Bell
Maybe try this:
Voice translation-rule 2222
rule 1 /^21255514\(..\)/ /0714\1/
Sample test of rule:
iecube01#test voice translation-rule 2222 2125551400
Matched with rule 1
Original number: 2125551400     Translated number: 071400
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
iecube01#test voice translation-rule 2222 2125551401
Matched with rule 1
Original number: 2125551401     Translated number: 071401
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
How do I post the rating in this new format?
William Bell
Maybe try this:
Matched with rule 1
Matched with rule 1
HTH.
Bill
Hi William,
ItĀ“s a great post. Could you tell me what would best practise for apllying those rules to a dial-peer? I have a DID range 7282829271-299 and I need to translate them to DNs 101-139 and I am not sure yet how to apply the translarion rules to a dial-peer.
Thanks in advance.
You apply translation profiles to dial-peers as follows:
dial-peer voice 101 pots
translation-profile outgoing name-of-translation-profile
OR
dial-peer voice 102 pots
translation-profile incoming name-of-translation-profile
In dial-peer 101 the translation profile is applied to calls using this dial-peer for the outbound leg. For 102, the translation is applied to the inbound leg. In both cases the pattern assigned to the dial-peer is matched before applying the translation rule.
HTH.
Bill
Hi William,
Once again thanks for the good clue. I did apply the rule to the dial-peer in outgoing direction to match outgoing call leg. It looks like the changed called ID does not make a change. However on the debug voice ccapi I can see that the rule ins being matched:
Calling Number=7282851072(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=017223306845(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Red Logica
   Account Number=, Final Destination Flag=FALSE,
   Guid=50EE77A2-478D-11E0-8DA0-E359F099615A, Outgoing Dial-peer=912
040198: Mar  7 01:01:57.764: //923/50EE77A28DA0/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=7282851072
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=017223306845
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
The caller ID displays on the called phone as the main namber from the DID range 7282829270 and never begin desplayd as 7282851072. Would that be something with the voice service provider, shall I speak to them?
Thanks in advance.
Are the trunks to your carrier ISDN? If so, check "debug isdn q931" and see what you are sending to the carrier for the calling party IE. If you find you are still sending  7282851072 but the called party still sees 7282851070 then your carrier's CO switch is introducing the problem.
HTH>
Bill
Rob Huffman
Hey Thomas,
To give Bill the nice rating he deserves here follow the steps in the attached doc-link
Bill + 5 points for this excellent work my friend!
How do I rate in the Support Forums?
https://supportforums.cisco.com/docs/DOC-8052
Cheers!
Rob
