Translation rule help
is there a way to combine these 3 rules to 1'
voice translation-rule 1
rule 5 /8881211/ /0051211/
rule 5 /8881212/ /0051212/
rule 5 /8881213/ /0051213/
Thaks
hasrat
1 ACCEPTED SOLUTION
Re: Translation rule help
Yes there is:
rule 1 /888121\([1-3]\)/ /005121\1/
This takes the last digit: either a 1, 2, or 3 (as indicated by [1-3]) and then places it in the replace string with the stored reference of \1.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
Anthony Holloway
Yes there is:
Anthony Holloway
Anthony Holloway
Anthony,
Thank you for your help.
hasrat
It would have been smart on my part, to actually test this before posting it.  Thankfully I nailed it blind.
Test Results
Router#! Show voice translation-rule 1
Router#sh run | sec rule 1
Router#
Router#! Test rule 1 with a non-matching number of 8881210
Router#test voice translation-rule 1 8881210
8881210 Didn't match with any of rules
Router#! Test rule 1 with a matching number of 8881211
Router#test voice translation-rule 1 8881211
Matched with rule 1
Original number: 8881211        Translated number: 0051211
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Router#! Test rule 1 with a matching number of 8881212
Router#test voice translation-rule 1 8881212
Matched with rule 1
Original number: 8881212        Translated number: 0051212
Router#! Test rule 1 with a matching number of 8881213
Router#test voice translation-rule 1 8881213
Matched with rule 1
Original number: 8881213        Translated number: 0051213
Router#! Test rule 1 with a non-matching number of 8881214
Router#test voice translation-rule 1 8881214
8881214 Didn't match with any of rules
Router#
Router#! Done
Anthony Holloway
Anthony Holloway
192
