Translation rule problem
Hey guys
I have a new CME setup.  V9.1 and all is progressing well - so far.
I have setup a sip trunk to a sip provider. I cannot seem to get my translation rule to function - can you see why?
voice translation-rule 1
rule 1 /^9\(.*\)/ /\1/
rule 2 /^2../ /3044*023/
I am wanting to strip the 9 from the outgoing number.  thats ok because the call is forwarded to the sip provider without the 9.
The second rule should replace the internal extension number (221) and replace with the pilot number 3044*023.
I have looked at the wireshark trace and the extension number 221 is getting sent.
If i replace extension 221 with the 3044*023 - the ephone-dn the call is processed sucesfully by the sip provider and it rings the number succesfully.
Because of this i feel it must be a translation issue rather than any other issue.    The below log shows rule 1 stripping the 9 but rule 2 does not seem to trigger.
VoIP Translation Rule debugging is enabled
LR-2911#
Oct 14 09:32:22.301: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgro
up_internal:
   Voice port 0x3E0F7050 dsl=-1 timeslot=0 does not belong to any trunk group
Oct 14 09:32:22.301: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_RegXruleNumInfo
: stack=0x23E56B8C; count=1
Oct 14 09:32:22.301: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_callinfo_intern
al: numinfo=0x23E6F820
Oct 14 09:32:22.301: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_push_RegXruleNumInf
o_internal: stack=0x23E56B8C; count=1
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_translate_exist_internal:
no rule for callback-number number
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_profile_translate_interna
l: number=221 type=unknown plan=unknown numbertype=calling
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_get_RegXrule: Invalid tra
nslation ruleset tag=0
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_profile_match_internal: E
rror: ruleset for calling number not found
l: No match: number=221 type=unknown plan=unknown
l: number=902083398000 type=unknown plan=unknown numbertype=called
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_profile_match_internal: M
atched with rule 1 in ruleset 1
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/sed_subst: Successful substitution
; pattern=902083398000 matchPattern=^9(.*) replacePattern=\1 replaced pattern=02
083398000
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_subst_num_type: Match Typ
e = none, Replace Type = none Input Type = unknown
Oct 14 09:32:24.921: //-1/5CC4DE3AA581/RXRULE/regxrule_subst_num_plan: Match Pla
n = none, Replace Plan = none Input Plan = unknown
l: xlt_number=02083398000 xlt_type=unknown xlt_plan=unknown
l: number= type=unknown plan=unknown numbertype=redirect-target
rror: ruleset for redirect-target number not found
l: No match: number= type=unknown plan=unknown
l: number= type=unknown plan=unknown numbertype=redirect-called
rror: ruleset for redirect-called number not found
Oct 14 09:32:24.925: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_RegXruleNumInfo
Oct 14 09:32:24.925: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_callinfo_intern
Oct 14 09:32:24.925: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_push_RegXruleNumInf
Oct 14 09:32:24.949: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_callinfo_intern
al: numinfo=0x0
Oct 14 09:32:25.869: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_RegXruleNumInfo
Oct 14 09:32:25.869: //-1/5CC4DE3AA581/RXRULE/regxrule_stack_pop_callinfo_intern
i have tried a number of variations with rule 2:
rule 2 /221/ /3044*023/
rule 2 /2../ /3044*023/
but nothing seems to work.   Can anybody see any flaw in the rule 2? or offer any help?
John
1 ACCEPTED SOLUTION
Hi John,
You want to strip 9 from a called number and convert calling number to 3044*023, is it correct?
So if you are calling from internal extension 250 to public number 902083359000 you need to send to sip-provider A-number 3044*023 and B-number 02083359000, am I right? To do so you have to implement two translation-rules, as I've mentioned before. One for calling number and another for called.
voice translation-rule 2
rule 2 /^2..$/ /3044*023/
voice translation-profile DiscardDigit9
translate called 1
translate calling 2
dial-peer voice 1 voip
translation-profile outgoing DiscardDigit9
Please check it.
Kind regards,
Andrew C.
Kind regards, Andrew C.
Hi John.
Are you trying to translate incoming or outgoing calls?
Which is the called number and the expected translated number.
Please attach your running config.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
this is translate outgoing.  Ill be looking at the incoming sip next.
the called number is 90208335xxxx    i expect to see the 9 stripped.
The sip provider also needs to see the pilot number (user name) of 3044*023 rather than the internal extension number 221 that is currently sent.
sanitised config:
LR-2911#sh run
Building configuration...
Current configuration : 10556 bytes
hostname LR-2911
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone GMT 1 0
ip cef
ip domain lookup source-interface GigabitEthernet0/1
ip name-server 172.20.0.20
no ipv6 cef
quit
voice-card 0
voice service voip
ip address trusted list
  ipv4 178.248.33.114 255.255.255.255
allow-connections sip to sip
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
translate called 1
license udi pid CISCO2911/K9 sn FCZ1718607E
license accept end user agreement
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
redundancy
no ip ftp passive
interface Embedded-Service-Engine0/0
no ip address
interface GigabitEthernet0/0
description Outside IF
ip address 172.20.15.10 255.255.0.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
description Inside IF
ip address 192.168.11.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
tftp-server flash0:term62.default.loads
tftp-server flash0:term42.default.loads
tftp-server flash0:cnu42.9-2-1TH1-13.sbn
tftp-server flash0:apps42.9-2-1TH1-13.sbn
tftp-server flash0:dsp42.9-2-1TH1-13.sbn
tftp-server flash0:cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash0:jar42sccp.9-2-1TH1-13.sbn
tftp-server flash0:SCCP42.9-2-1S.loads
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
mgcp profile default
destination-pattern 90..........
session protocol sipv2
session target dns:sip.cloudcalling.co.uk
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 3044*023 password 7 xxxxxx realm sip.cloudcalling.co.uk
authentication username 3044*023 password 7 xxxxxx realm sip authentication username 3044*023 password 7 xxxxx realm sip.cloudcalling.co.uk
nat symmetric role passive
nat symmetric check-media-src
no remote-party-id
retry invite 3
retry register 3
timers connect 100
registrar dns:sip.cloudcalling.co.uk expires 3600 refresh-ratio 20 auth-realm s
gatekeeper
shutdown
telephony-service
protocol mode ipv4
no auto-reg-ephone
max-ephones 25
max-dn 40
ip source-address 192.168.11.254 port 2000
max-redirect 5
cnf-file location flash:
load 7942 SCCP42.9-2-1S.loads
date-format dd-mm-yy
voicemail 401
max-conferences 8 gain -6
web admin system name xxx secret 5 xxx
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Oct 08 2013 16:25:28
ephone-dn  21  dual-line
label Joyce
description OPD Manager
name Joyce
ephone  21
mac-address 1CE6.C773.3CB7
username "Joyce"
type 7942
button  1:21
Hi John,
You have to create two translation rules since you want to implement digit-translation for both called and calling numbers. If I understood you correctly, you need to do this:
translate called 1
translate calling 2
and then apply the translation-profile on the outbound dial-peer.
Kind regards,
Andrew C.
Re: Translation rule problem
Hi John,
In order to replace A-number 2.. with the number 3044*023 you should do something like this:
voice translation-rule 10
rule 1 /^2..$/ /3044*023/
voice translation-profile CALLS_TO_SIP
translate calling 10
dial-peer voice 300 voip ! outbound dial-peer to sip-provider
translation-profile outgoing CALLS_TO_SIP
Kind regards,
Andrew C.
Hi Andrew
Thanks for that.  I have updated my config with that and get the following results:
LR-2911# test voice translation-rule 1 902083359000
Matched with rule 2
Original number: 902083359000   Translated number: 903044*0233359000
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
LR-2911#
Oct 14 10:35:24.672: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=9
02083359000 rule precedence=1
Oct 14 10:35:24.672: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution
; pattern=902083359000 matchPattern=2.. replacePattern=3044*023 replaced pattern
=903044*0233359000
Oct 14 10:35:24.672: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Typ
e = none, Replace Type = none Input Type = none
Oct 14 10:35:24.672: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Pla
n = none, Replace Plan = none Input Plan = none
LR-2911#
the 9 isnt stripped and the new number is definately incorrect.
Can you see what is wrong with my original rules:
Oct 14 10:44:52.541: %SYS-5-CONFIG_I: Configured from console by xxx on vty0
(172.20.4.75)
Matched with rule 1
Original number: 902083359000   Translated number: 02083359000
LR-2911#
Oct 14 10:44:54.893: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=9
02083359000 rule precedence=2
Oct 14 10:44:54.893: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution
; pattern=902083359000 matchPattern=^9(.*) replacePattern=\1 replaced pattern=02
083359000
Oct 14 10:44:54.893: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Typ
Oct 14 10:44:54.893: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Pla
LR-2911#
I seem to strip the 9 - but cannot translate the internal number.
thanks
John
Hi John.
in this case you can also use calling-info sip-to-pstn number set 3044*023
Carlo
Hi John,
translate called 1
translate calling 2
Please check it.
Kind regards,
Andrew C.
Hi Andrew
You did, and i didnt read your post correctly.
Thanks soooo much.  Ive spent some considerable time on this.
John
You're welcome, I'm glad it helped )
Kind regards,
Andrew C.
257
