Community Member
Translation Rule
Dear All,
I am running CME 7.0. The problem which i m facing is that on my cisco IP Phone I am not able to see complete digits of received (international) calls only on my ip phone display like for example if a calling number is 00966507660345, it just shows the number 0966507660345 skipping the first 0. Please let me know how i can over come this problem.
Your consideration in this regard will highly be commendable.
Thanks & Regards,
Malik.
2 ACCEPTED SOLUTIONS
Re: Translation Rule
i will crate a translation rule that match a number with number of digits same as the one you put ( 12 digits) + 00
voice translation-rule 1
rule 1 /\(0............\)/ /0\1/   -- you can put more than one line liek rule 2, 3 .. and also the number of dots you can change it basd on the number of
digits you recieve for example this one will math any number start with 09665 /\(09665.*\)/ /0\1/
voice translation-profile ADD0
translate calling 1
then you need to apply it under your PSTN pots dial-peer
dial-peer voice x pots     --- x the number of your pots dial-peer
translation-profile incoming ADD0
verification:
Router#test voice translation-rule 1 0966507660345   -- incoming number
Matched with rule 1
Original number: 0966507660345  Translated number: 00966507660345  -- resulted calling number
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
good luck
if helpful Rate
just follow the example above
translate calling 1
verification:
Matched with rule 1
good luck
if helpful Rate
Community Member
Hi marwanshawi,
Thanks for your reply. Can you please tell me how i can include only one "0" infront of all international calls only. Like for example i just want to se international incoming call on ip phone display as:
00966 or
00971 or
00924 etc etc....
Please help me in this regard...or Can you plz tell me the exact commands,
Malik.
Community Member
hi,
i tried with your configuration but i failed...can you please check my configuration please...i will be very thankful to you...
Community Member
cme-3825#
cme-3825#
cme-3825#test voice tr
cme-3825#test voice translation-rule 2 0966507660365
Matched with rule 2
Original number: 0966507660365  Translated number: 00966507660365
cme-3825#
hope it may help you...
try to make like this
rule 1 // /0/
rule 2 /\(0............\)/ /0\1/
good luck
Community Member
no luck
878
