translation rule
my company 65XX switch having this config
translation-rule 1
RULE 1 ^...4
DIAL-PEER VOICE 4001 VOIP
preference 1
destination-pattern [0-2,5-9]..$
translate-outgoing called 1
session target ipv4:10.10.10.1
incoming called-number .T
preference 2
session target ipv4:10.10.10.2
dial-peer voice 8000 pots
destination-pattern .T
incoming called number [34]..$
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits all
is there anyone can give me some explanations for this ,what will happening somebody calls to the company,and somebody calls outside company
national number:8 digits
internal numbering:4 digits
ccm1 =10.10.10.1
ccm2 =10.10.10.2
thanks in advance
tom
  • IP Telephony
Re: translation rule
please urgent please ???
It looks like the translation rule just takes whatever the outgoing numbers end in a 4 and does something, but I can't tell....
It looks like some of the command is missing.
The easiest way to see what this rule does is to just use this command:
test voice translation rule
and plug in a digit string, then it will give you the output digit string of what it looks like is applied by the rule.
the destination-pattern statement is telling the switch for any calls to a destination with
the following:
1st number - between 0 and 2
2nd number - between 5 and 9
3rd number - anything x
4th number - anything x
Example:
05xx, 06xx, 07xx, 08xx, 09xx
15xx, 16xx, 17xx, 18xx, 19xx
25xx, 26xx, 27xx, 28xx, 29xx
send to your CallManagers, with the primary 1, processing to that server first and the primary 2 going to that server second.
As far as the pots Dial peer goes, it looks like it ONLY ALLOWS 4-digit DIDs in the range of:
3xxx to 4xxx to dial out to the PSTN.
post a more completed config and i could give you some more detail.
please find the cofig attached here
246
