Translation rule
Hi experts
I have a requirements for a customer which wants to redirect External Calling numbers without CallerID to an specific extension.
Is that possible?
If so which rule can i use?
Hall of Fame Super Gold
Re: Translation rule
Are you using callmanager? Which version? Which kind of gateway, which kind of lines, which protocol are you running on the gateway?
Yes, CCM 4.1(3)sr4d
H323 GW.
that should be possible on the GW using a DP with "answer-address", but there could be an easier way made on CCM itself, perhaps someone else knows.
101
