Community Member
Translation rules setting
Hi all,
I am fresh in translation rules. Anyone know what problem the following is. The translate rule seems not working.
voice translation-rule 1
rule 1 /144*/ /202449144/
voice translation-profile CML
translate calling 1
dial-peer voice 888889 voip
destination-pattern 144.
translation-profile outgoing CML
Thanks a lot
Leung Che Man
Re: Translation rules setting
Please post the number that is being dialled by the caller, the number you want this to be translated to and the output that the translation rule is currently giving.
(You can test the translation rule using test voice translation-rule 1 ?????).
Community Member
I dial '1445' but it cannot be translated.
2157 ORG T0 g729br8 VOIP P1445 0.0.0.0:0 D1
2156 ANS T0 None TELE P8827 D10
nshk-cme#test voice translation-rule 1 1445
Matched with rule 1
Original number: 1445 Translated number: 2024491445
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
nshk-cme#
Leung Che Man
From the output of the test command number looks like it is being translated ok.
Can whatever system the dial-peer voice 888889 voip points to provide any debugs?
Community Member
I change the 'translate calling' to 'translate called' then I can dial 1445 and reach 2024491445.
rule 1 /^144/ /202449144/
translate called 1
Thanks a lot
Leung Che Man
147
