Translation Rules with Greek symbols
                    Is this a valid H323  translation rule for 9 + 7 dialing    rule1/.*\(3...$V)/Λ1/
The reason I ask is because it has greek Symbols.
Thank you
1 ACCEPTED SOLUTION
nope , it doesnt look like a correct rule
it should be more like this
rule 1 /.*\(3...\)$/ /\1/
regards
Anurag Siddhu
I guess you are asking the wrong question,
Translation rule only translates the number , they dont actually match the called party\calling party number like dial-peers ( pots or voip).
they simply match the calling\called party number and change them to a different number
as per rule.
so you can simply test the rule ,
this rule is translating a number as follows
for  eg
it will modify the number " 76549873333" to " 3333"
Anurag Siddhu
Thanks for the response, But is it a valid translation rule ? rule1/.*\(3...$V)/Λ1/
regards
Anurag Siddhu
164
