Trasfer for Analog Phones (FXS)
Hello, collegues.
I have a problem with configuring function transfer on CCME for the analog device. Can you say, please, in what ways it can be realized? And also, do you known were is the examples of config with realization of this function?
On cisco.com I have found clause "SCCP Controlled Analog (FXS) Ports with Supplementary Features in Cisco IOS Gateways". However, using given clause to create transfer, I could not achieve positive result.
Therefore, I address to you.
TIA
Hall of Fame Super Gold
Re: Trasfer for Analog Phones (FXS)
Why that didn't not work for you? Does the STCAPP work, can you use the FXS ports in SCCP modem to make and palce calls ?
Thank you, for youre answer.
I was configure STCAPP on my CCME. When I want to do transfer - I press hook-flash and CCME give me tone. So I dial number of transfer-to. But after dial number call don`t transered - it remain on the same FXS.
Hi, in feature mode, the FAC for transfer is #2, check:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a00806cab75.html
Also make sure the ephone-dn is dual-line.
I have following scheme:
AP---CCME---AP(333)
(100) |
AP(444)
where is AP - it is analog phone.
So I call from 333 to 100. Call is terminating. On the phone 100 I press #2 - CCME give me tone. I dial 444, but transfer don`t work. In addition I hear on phone 333 dialed number from 100.
There is my config. Can you check, please, my config
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice-card 0
no dspfarm
archive
log config
hidekeys
interface GigabitEthernet0/0
duplex full
speed 100
interface GigabitEthernet0/1
ip address 172.23.4.4 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.23.4.1
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
timeouts ringing infinity
station-id number 100
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
sccp local GigabitEthernet0/1
sccp ccm 172.23.4.4 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 100 pots
service stcapp
port 0/0/2
dial-peer voice 333 pots
destination-pattern 333
port 0/0/0
dial-peer voice 444 pots
destination-pattern 444
port 0/0/1
telephony-service
max-ephones 58
max-dn 192
ip source-address 192.168.1.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
transfer-pattern ...
create cnf-files version-stamp 7960 Jan 24 2008 13:52:33
ephone-dn 1 dual-line
number 100
ephone 1
mac-address 3C39.99D2.9002
button 1:1
end
CCME#
Hi, if you look into:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html
there is a note about the need of not use "station-id number". Can you check that is you case ?
I disabled station-id number on voice-port. But, it is not correct problem.
I am frightened with following record:
TAG Type AD OUT
port MIN STAT
100 pots up down
It is correct, what the status down at dial-peer on which it is applied stcapp?
Hi, since the stcapp config is a bit complicated, is difficult to diagnose what is wrong from remote, it is one of these cases where one needs to be on site to troubleshoot.
As time permits I will try a config like your to see if I can have it working.
Thanks a lot for active participation in the decision of my problem. If you will have news, inform me, please. I try to solve this problem about 2 weeks.
164
