Community Member
Traskation Pattern Not Working
I am having Call Manager 4.2 with 2811 router configured as MGCP Gateway. Was having only one main number coming through the router to the reception phone through the router and then to CCM. It was configured on the Gateway configureation --> Endpoints and was forwarding to the reception phone.
Due to a new requirment of having another number for some managers, we have got 2 more numbers thriugh the same PRI line and want to trasnfer based on Called number.
I have removed forwarding from the gateway configuration and created traslation patters for the same.  The traslation pattern says, the main number ( called number and then forward to the corresponding extensions.
But always, the calls are getting diverted to reception phone and not other phones. The traslation pattern doesnt seems to be working..
Your advices are highly appreciated.
Gokul
Most likely a CSS/PT issue, check that.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Hi Gokul,
                Can you paste your translation pattern config here. Also let us know the scenario that you are dealing with .
Abdul
Community Member
Re: Traslation Pattern Not Working
I have checked the Partition and CSS. All are same.  Please find the below detailed scenario.
There is a PRI Line terminated to Voice Router.
Voice router is configured as MGCP gateway in CCM 4.2
All the calles were directly forwarded to the CTI route point which is to the CRS system.
Currently, we have got an additional number which needs to be dorectly forwrded to one extension and not to the CRS system.
So if a call is coming to the number 17225227  it needs to be trasferred to the CTI Route Point which will go to CRS
If the call is coming to 80008030 it needs to be forwarded to the extension 836
I have attached the screen shots of the two Traslation Pattern created and the gateway configuration.  Kindly let me know how to solve this issue.
Gokul
239
