Trouble getting IP7941 phone to register with CME 8.6 server?
I am trying to bring up a test CME 8.6 server, but am having issues getting my test IP7941G phone to register with the system.
The phone definitely gets an IP address from the CME server, but it looks like the problem is that it's not getting its appropriate phone load, even though I appear to have the right files place and the IP7941's load file is exactly the same as the load that the CME server is serving up.   Any ideas?
Here are the config details:
IOS version: c2800nm-spservicesk9-mz.151-4.M7.bin
Content of flash:/phones/
    3  -rw-     2911906  Jan 12 2014 16:25:36 +00:00  apps41.9-1-1TH1-16.sbn
    4  -rw-      517968  Jan 12 2014 16:25:40 +00:00  cnu41.9-1-1TH1-16.sbn
    5  -rw-     2189038  Jan 12 2014 16:25:56 +00:00  cvm41sccp.9-1-1TH1-16.sbn
    6  -rw-      541453  Jan 12 2014 16:26:00 +00:00  dsp41.9-1-1TH1-16.sbn
    7  -rw-     1629575  Jan 12 2014 16:26:10 +00:00  jar41sccp.9-1-1TH1-16.sbn
    8  -rw-         660  Jan 12 2014 16:26:12 +00:00  SCCP41.9-1-1SR1S.loads
    9  -rw-         660  Jan 12 2014 16:26:12 +00:00  term41.default.loads
   10  -rw-         660  Jan 12 2014 16:26:12 +00:00  term61.default.loads
Current configuration : 7653 bytes
! Last configuration change at 18:23:38 UTC Sun Jan 12 2014
version 15.1
service password-encryption
hostname bdc-cme
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.151-4.M7.bin
boot-end-marker
card type t1 0 3
enable secret 4 LcV6aBcc/53FoCJjXQMd7rBUDEpeevrK8V5jQVoJEhU
enable password 7 0313541D0301
no aaa new-model
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.20.1 10.10.20.20
ip dhcp pool VoiceVLAN
network 10.10.20.0 255.255.255.0
option 150 ip 10.10.20.1
default-router 10.10.20.1
ip domain name wovensystems.local
ip multicast-routing
no ipv6 cef
isdn switch-type primary-5ess
voice service voip
ip address trusted list
  ipv4 10.10.20.0 255.255.255.0
license udi pid CISCO2821 sn FTX1051A1KN
archive
log config
  hidekeys
controller T1 0/3/0
cablelength long 0db
pri-group timeslots 1-24
ip ssh time-out 60
ip ssh rsa keypair-name woven.systems-1
ip ssh version 2
interface GigabitEthernet0/0
ip address 10.10.20.5 255.255.255.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.10.20.10 255.255.255.0
service-module ip default-gateway 10.10.20.5
ip default-gateway 10.10.20.1
ip forward-protocol nd
ip http server
ip http secure-server
ip http timeout-policy idle 120 life 86400 requests 10000
ip http path flash:/gui
ip route 10.10.20.10 255.255.255.255 Service-Engine1/0
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:/phones/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:/phones/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:/phones/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:/phones/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:/phones/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/term61.default.loads alias term61.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
control-plane
voice-port 0/3/0:23
mgcp profile default
telephony-service
max-ephones 48
max-dn 48
url services http://10.10.20.10/voiceview/common/login.do
url authentication http://10.10.20.5/CCMCIP/authenticate.asp
load 7941 SCCP41.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
time-zone 5
voicemail 9000
max-conferences 8 gain -6
web admin system name admin password password
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
type 7961
ephone  1
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password 7 06315F371F404748
login
transport input all
scheduler allocate 20000 1000
sntp server 10.10.10.23
end
Re: Trouble getting IP7941 phone to register with CME 8.6 server
Hello
What do you see in the console log? Did you run the debug tftp event in order to check any error ? If not can you please try run this debug ?
Br, Nadeem Please rate all useful post.
From a console session, I don't see any event messages scrolling while the phone is trying to register.  What are the explicit commands to turn on tftp degbugging and to then be able to see the debug events scroll from a console session?   I'm not familiar with how to do this.
Run the debug on the router "debug tftp event"
Unplug and plug the phone or resetting. Do terminal monitor on the router you will some events and message on the router.
For phone console try clear history before unplug and plug the phone .
Thanks! I will try this shortly and let you know what I find out.
Try adding the below and see if it helps.
telephony-service
ip source-address 10.10.20.5 port 2000
no create cnf-file
create cnf-file
Also, your option 150 statement and the default router statement  is pointing to 10.10.20.1.  Shouldn't it be 10.10.20.5?
I modified the option 150, to point to m DHCP server, but when I deleted and recreated the CNF files, they all seem to be getting written to a directory on flash called flash:/its/vrf1.   Is this supposed to happen?  I think the failure to properly generate the CNF files is what's breaking the server.
I stand corrected.  Changing option 150 and adding ip source-address DID allow the phone to register!!!  Progress!  Thank you so much.
No problem.  I struggled with a similar issue for a few hours the other night.  I thought I would save you some time.
Missed that ip source-address command missing in the config under telephony-service.
telephony-service
max-ephones 48
max-dn 48
time-zone 5
voicemail 9000
Br,
Nadeem
Sorry.  I missed this question.  When you create the cnf files, they get stored in the /its/ virtual directory.  You can see all of the files in that directory with the show telephony-service tftp-bindings command.
715
