Community Member
Trouble Installing CUPM
I am trying to install Provisioning Manager and I the installation fails everytime with this error:
Postgres install failed with error code 1603
I can't seem to get the thing installed. Any help would be appreciated.
Hall of Fame Super Red
Re: Trouble Installing CUPM
Hi Chris,
Not sure if you had seen this info;
If an error message appears similar to the following appears, it means that the installation has failed:
Before trying to install Provisioning Manager again, you must clean up the system
Cleaning Up a Failed New Installation
If Provisioning Manager did not install correctly, you must first clean up the system before trying to
install Provisioning Manager again. These procedures are for a failed new installation of Provisioning
Manager 1.1. If you need to clean up a failed upgrade of Provisioning Manager 1.0 to 1.1, see Restoring
Provisioning Manager 1.0 when Provisioning Manager 1.1 Installation Fails, page 2-16.
After a failed installation, do the following:
Delete the CUPM installation folder. If you selected the default location during installation, it is
Delete the Documents and Settings\cupmuser folder.
Remove the Windows user; cupmuser (cupmuser is the default name provided during installation).
The Windows user name can be different, if you changed it during installation. For instructions on
removing the Windows cupmuser, see Removing the CUPM Windows User,
Step 1 On the Windows desktop, select Start > Settings > Control Panel.
Step 2 Double-click Administrative Tools.
Step 3 Double-click Computer Management.
Step 4 In the console tree, under Local Users and Groups, click Users.
Step 5 Right click the user account cupmuser and delete it.
Note The Windows username, cupmuser, is the default name provided during installation. The
Windows username can be different, if you changed it during installation.
Step 6 Delete cupmuser's home direcotry. The default location is in the directory C:\Documents and Settings\.
From this doc;
Hope this helps!
Community Member
Yes, thanks I saw that in the installation doc. The problem is that this error occurs every time I try to install. I can do the clean up process as much as I want but still get the same error.
I got it installed after about 5 tries, disabling anti-virus helped and using a server with enough memory.
But now since i got it installed - i can't do anything with it. I get this error everytime i try to configure anything:
Error Code: SHARED-2263
Message: Exception caught storing wizard attributes 1: Batch entry 0 INSERT INTO tableWizardAttributes (wizardID, attribute, value ) VALUES (1, syncInfrastructure-status, NULL) was aborted. Call getNextException to see the cause.
anyone else seen this ?
