Trouble loading the SQL bind vulnerability patch
Hi All,
I am having troubles loading the SQL bind vulnerability patch to my LAB.
I had hoped to get it loaded here before trying it on the production network.
My version of CUCM fis 9.1.1.10000-11
The installation begins normally, but gets an "unknown error"
Any ideas please?
thanks
Amanda
  • IP Telephony
Re: Trouble loading the SQL bind vulnerability patch
Have you checked the MD5?
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jamie,
Thanks for that, but the error message does not show the MD5 at all.
It only says an "unknown" error occurred.
I am not sure how to view the logfiles using the command line, but that is probablly where I need to get to.
Any tips on looking at those log files?
thanks
Amanda
985
