Trouble w/ Hunt Group going to Voice Mail
If someone could help me with an seemingly odd issue I'm having, I'd appreciate it. What I have are three line groups that coorespond to 3 Hunt Lists. These are used for tiering our IT Operations group. The Hunt Pilot that coordinates all this have a number of 11700. Basically what I'd like to see happen is after the last group doesn't answer I want the caller to go to the voicemail on 11701. What I've done is added the 11701 number to the Forward Hunt No Answer/Busy settings within the 11700 Hunt Pilot. The odd thing about this is that whenever I test it the calls go through but I get directed to our company's main greet which is 11775. Any suggestions on why this would be happening?
1 ACCEPTED SOLUTION
Re: Trouble w/ Hunt Group going to Voice Mail
Unity and CUC use the original called number to route to VM, what you need to do is add the hunt pilot DN as an alternate extension to the subscriber you want to get the VM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
142
