Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Trouble with 2821 and VIC2-4FXO
I have a 2821 with a VWIC2-1MFT-T1/E1= and a VIC2-4FXO. I have my T1 working inbound and outbound but cannot get inbound calls working on the FXO ports. The call rings once, then goes to dial tone. The follow error is received.
*Nov 6 23:06:23.822: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal: Voice port 0x450E38CC does not belong to any trunk group
*Nov 6 23:06:23.826: //-1/BA99D137800E/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x455F7A44; count=1
*Nov 6 23:06:23.826: //-1/BA99D137800E/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
*Nov 6 23:06:23.826: //-1/BA99D137800E/RXRULE/regxrule_stack_push_RegXruleNumInfo: stack=0x455F7A44; count=0
I am not sure what the inbound digits are on that line so do I need to create a catch all dial-peer and if so how do I do that?
Thanks in advance.
Adam
1 ACCEPTED SOLUTION
Re: Trouble with 2821 and VIC2-4FXO
Simply create a dial-peer with a session target for your CallManager with destination pattern of the opx number. For example.
voice-port 0/2/0
trunk-group VIC2-4FXO
connection plar opx 6750
caller-id enable
dial-peer voice 1000 voip
description *** CallManager Pattern ***
preference 1
destination-pattern 6...
translate-outgoing calling 1
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.1.1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1001 voip
preference 2
voice-class codec 1
session target ipv4:192.168.1.2
no vad
Allan.
Hall of Fame Super Gold
this would be your catch-all incoming DP to avoid secondary dialtone:
dial-peer voice 111 pots
incoming called-number ...
direct-inward-dial
and this is how you group lines for outgoing, ad direct inbound:
voice-port X/0
trunk-group pstn
connection plar opx 222
voice-port X/1
trunk-group pstn
dial-peer voice 222 pots
destination-pattern 9T
trunkgroup pstn
Thanks! My goal is to use the T1 for all outbound calls, while accepting calls from the FXOs and the T1.
The following...
voice-port 0/1/0
trunk-group pstn
got rid of the secondary dialtone.
How do I take calls from just that FXO port and send to a device within CCM? I am used to using the destination-pattern 5... (example) to send the call and then using a translation pattern to mp the incoming digets to an extension.
Thanks again!
Adam
voice-port 0/2/0
caller-id enable
preference 1
voice-class codec 1
voice-class h323 1
no vad
preference 2
voice-class codec 1
no vad
Allan.
Thats it, I am all set. Thanks guys
1163
