Bronze
Trouble with dialing the UK
Were having issues dialing the UK from or California office. We can dial all of our international sites except the UK. Below is a debug for the dial peer and q931 on the PRI. The number were calling is British Telecom as an example.
Dial String=9011441189241400, Expanded String=9011441189241400, Calling Number=
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Aug 28 13:57:59.577: //-1/1B5FDEA3B9C1/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=34 Is Matched
*Aug 28 13:57:59.577: //-1/1B5FDEA3B9C1/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
*Aug 28 13:57:59.577: //-1/1B5FDEA3B9C1/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=34
*Aug 28 13:57:59.585: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 4088632913
*Aug 28 13:57:59.589: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x1 0x1, Called num 011441189241400
*Aug 28 13:57:59.589: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0312
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '4088632913'
Plan:ISDN, Type:National
Called Party Number i = 0x91, '011441189241400'
Plan:ISDN, Type:International
*Aug 28 13:57:59.693: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8312
Cause i = 0x829C - Invalid number format (incomplete number)
Any ideas or has someone seen this before?
Thanks.
1 ACCEPTED SOLUTION
Re: Trouble with dialing the UK
You need to call your provider & ask them what plan & type is required. Then you can change to that using either a translation rule or an isdn map on your PRI interface. I had this same problem where I was able to call certain parts of Europe, but not everywhere. In my case I needed to add
isdn map address 011.* plan isdn type national
which changes all of my International to "type" National.
Have you contacted your carrier about this, if so what did they say? Im thinking that maybe they dont want to see the "011" and just want to see the number with the type marked as "international".
VIP Super Bronze
Can you try my number..442079011226.
Also send the full debug isdn q931...
We need to know the direction of the disconnect...Is it from your telco or gateway?
I tried the number from here in London and it works okay..01189241400
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Silver
The number is correct and digit lengt is correct I would like at the type of call you are sending to the Telco perhaps change it to unknown ?
VIP Super Bronze
This is the meaning of the cause code you are experiencing....
Invalid number format...This call happen when you are calling out using a network type number (enterprise) when you should be calling out unknown or national.
Here in the UK we use Unknown..so you may want to change from international to unknown..and try again
Bronze
If this is the second reply sorry...
I have contacted ATT and they said they were able to call the UK from our switch and that the problem was on our router.
Below is all the debug q931 when calling aokanlawon....
*Aug 28 15:34:07.937: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 4088632913
*Aug 28 15:34:07.941: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x1 0x1, Called num 011442079011226
*Aug 28 15:34:07.941: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0319
Standard = CCITT
Channel ID i = 0xA98381
Exclusive, Channel 1
Called Party Number i = 0x91, '011442079011226'
*Aug 28 15:34:08.057: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8319
I'm new to voice so I'm just getting started...please be patient....where do I change to unknown??? In the dial-peer cor list??
Thanks for the help.
Silver
Do you have CCM or express ?if CCM then as a quick test do the following
Locate the gateway you use for the call via the route pattern for 9.11 l, if you are lucky you may have a specific gateway for international calls
2. On the gateway page locate the section -
Call Routing Information - Outbound Calls
3. Look for Called party IE number type and maybe Calling party IE number type and change them to unknown
4. Make a test call again and see if it works. If it does leave it as it is but make test calls on the other possible route patterns in case it effects them
if CME you need to use translations to change the type to unknown on the dial -peer or maybe hard code it directly on the dial-peer for your external calls
Bronze
Here is what my current dial peer looks like after I added the numbering-type unknown...is this the correct command?????
dial-peer voice 34 pots
translation-profile outgoing CALLERID
destination-pattern 9011T
port 0/0/1:23
prefix 011
After the change I still get...
Calling Number=, Called Number=9011441189241400, Peer Info Type=DIALPEER_INFO_SPEECH
*Aug 28 16:11:34.617: //-1/C7FEE611BB49/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9011441189241400
*Aug 28 16:11:34.617: //-1/C7FEE611BB49/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=34
*Aug 28 16:11:34.625: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 4088632913
*Aug 28 16:11:34.629: ISDN Se0/0/1:23 Q931: Applying typeplan for sw-type 0xD is 0x1 0x1, Called num 011441189241400
*Aug 28 16:11:34.629: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0327
Standard = CCITT
Channel ID i = 0xA98384
Exclusive, Channel 4
*Aug 28 16:11:34.749: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8327
Is this the correct change???
Bronze
Sorry...this is a call manager express router where this is happening.
Did ATT say whether or not they want the 011 sent to the switch. I know generally if your PRI is on a 5ess switch, then they dont want to see the 011. Try stripping the 011 and leave the call type as international. I did this just the other day and it worked.
voice translation-rule 1
rule 1 /^9011/ // type unknown international
voice translation-profile INTL
translate called 1
voice-port 0/0/1:23
translate outgoing INTL
Try that and see if the call goes thru. I did this for one of my customers who couldnt dial intl and ATT was their provider.
Hope that helped.
Bronze
Thanks for the help,
The q931 debug still shows the call as International after the change...if I did it correctly. Attached is the current voice config on the router. Please keep in mind that all other international calls work fine....only the UK does not.
Bronze
To answer your question ATT did not say anything about 011 being in the call. When I dial France 011 goes out the PRI with no issue.
Mike, see if you can do some testing with your carrier, and they can setup traps in the switch to see what exactly is being sent out when you make the call, and they should be able to tell you what they need to see coming from the router in order for the call to be successful.
I had an issue like this yesterday, the customer could make all intl calls, except for one number in austria. They could even call other numbers in austria with no issue. When we tested with the telco, the issue ended up being in the long distance carrier's switch and they were able to resolve the issue.
Hope that helped.
VIP Super Bronze
Can you confirm, what call processing agent you are using.
If you are using Callmanager, the change has to be made in callmanager
Bronze
The issue is with CME.
thanks.
VIP Super Bronze
Mike,
You should try ocnfiguring it under the Virtual serial interfcae...
i.e interface serial 0/0/1:23
Bronze
I don't see a translate command under the virtual interface...which command are you referring to?
Thanks.
Mike, I think the best way to handle this is to get in touch with ATT, and have them get into the switch while you make the call, so they can see which numbers are being presented, and they can tell you what needs to be sent from the router (011 or no 011) and how it needs to be sent (ie national, international, unknown)
VIP Super Bronze
I am talking about the number-type command
Bronze
Thanks !!! I opened a ticket with ATT a couple hours and just before they called I added...
to my PRI interface and it works. I learned alittle tech. She said that unknown can be crazy so they don't recommend using that. Using National keeps the 011 on there switch and using International they add 011 to it so you must strip the 011 from the number. She said either way it will work so I left it at national.
Thanks for everyone's help with this!!
Mike, glad to hear everything worked out for you. I have been encountering these issues with several of my customers as of late, so I have been learning a lot from service providers as far as what different switches expect when making calls.
Also thanks for the nice rating!!
Bronze
No problem on the ratings. I've got to keep you experts happy during my learning curve in my new environment....I'm sure I'll be asking more questions in the future. :)
Thanks again.
219
