Trouble with International calling
Hello I am fairly new to the CUCME but I have run into a problem I can not seem to find a good answer to.
One of the users needs to make international calls and this is ok by our company standards but for the life of me I can not get the system to recognize the number.
The CUCME collects all digits then gives me a error
"%VOICE_IEC-3-GW: CCAPI: Internal Error (Incompatible number type): IEC=1.1.28.1.22.0 on callID 39025"
I am running it trough a PRI and below are my config for the dial-peer
voice translation-rule 40
rule 1 /^9011/ /011/
voice translation-profile INTER_OUT
translate calling 40
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
trunk-group PRI 1
no cdp enable
dial-peer voice 99 pots
trunkgroup PRI
description INT test
translation-profile outgoing INTER_OUT
destination-pattern 9011T
here is what I see when I test it
EDM-CUCME#sh dialplan number 9011447900124912
Macro Exp.: 9011447900124912
No match, result=1
and of cource you see the dubug
023570: Feb 7 10:44:52.594: ephone-81[80/67]:Call Info DN 81 line 1 ref 13735 called 9trun                    011447900124912 calling 5419 alternateCalling 5419 origcalled 9011447900124912 calltype 2
023571: Feb 7 10:44:52.594: ephone-81[80/67][SEPE84040A3B0B5]:Call Info for chan 1
023572: Feb 7 10:44:52.594: ephone-81[80/67][SEPE84040A3B0B5]:SkinnyDisplayCallInfo callingName=Nicole Spencer
023573: Feb 7 10:44:52.594: ephone-81[80/67]:SkinnyDisplayCallInfo No-calledName
023574: Feb 7 10:44:52.594: peer_vdb is NULL for DN 81, chan 1 at SkinnyIsPeerNonSCCP
023575: Feb 7 10:44:52.678: %CALL_CONTROL-6-NUMBERING_TYPE_NO_MATCH: The called number numbering type did not matchThe event for the callid 33 is being discarded.
023576: Feb 7 10:44:52.678: %VOICE_IEC-3-GW: CCAPI: Internal Error (Incompatible number type): IEC=1.1.28.1.22.0 on callID 37801 GUID=3CE6B30950EA11E19C87D5AEB835F8D6
ANY Help would really be appreceated.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Green
Re: Trouble with International calling
This may an issue with the TON (type of number)
that you are sending to ISDN.
Can you try changing your translation rule
rule 1 /^9011/ /011/ type unknown international
Alex
Regards, Alex. Please rate useful posts.
Hall of Fame Super Silver
On your dial-peer 99 you need to prefix 011 back to it as it is striped, POTS dial peers strip all explicit match, so add this:
prefix 011
HTH,
Chris
I have added that and will get the user to test as I am not at that site but can you explain why I still get
No match, result=1
after changing it to
trunkgroup PRI
prefix 011
can u paste the debugs over here again after making the changes!!
thanks,
Vipul Jindal
Hi.
In your dial-peer remember to specify Voice Port ... in your case 0/0/0:23, otherwise dialpeer is in down state and no match will occur.
Your dial peer should be
prefix 011
  port 0/0/0:23
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo,
He has trunk group defined so no need for port command.
Chris
Yes Chris... sorry I haven't see it in the posted config.
From debug it seems that called number doesn't match any peer because dial-peer is in down state.
..@t805139
Can you please post a debug voip dialpeer all
Carlo
it would appear it is seeing two dial peers in my debug  dial peer 2 has a desitnation pattern of 9T right now
   dialstring=9011447900124912, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
151172: Feb 9 11:28:00.153: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=99
     2: Dial-peer Tag=2
151173: Feb 9 11:28:00.153: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
151174: Feb 9 11:28:00.153: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
151175: Feb 9 11:28:00.153: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
151176: Feb 9 11:28:00.153: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6614
151177: Feb 9 11:28:00.157: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9011447900124912, Called Number=, Voice-Interface=0x0,
151178: Feb 9 11:28:00.157: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=9011447900124912
151179: Feb 9 11:28:00.157: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
151180: Feb 9 11:28:00.157: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=9011447900124912T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
151181: Feb 9 11:28:00.157: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
And here is the latest debug on the call
172796: Feb 9 11:43:27.251: ephone-108[107/92]:SkinnyTryCall to 9011447900124912 instance 1 start at 0 secondary 0
172797: Feb 9 11:43:27.251: ephone-108[107/92]:SkinnyTryCall to 9011447900124912 instance 1 start at 0 secondary 0
172798: Feb 9 11:43:27.251: ephone-108[107/92][SEP2C3F38C8B95F]:
172799: Feb 9 11:43:27.251: bulk_speeddial_update_callinfo: 107
172800: Feb 9 11:43:27.251: ephone-108[107/92]:Call Info DN 108 line 1 ref 16525 called 9011447900124912 calling 4895 alternateCalling 4895 origcalled 9011447900124912 calltype 2
EDM-CUCME#
172801: Feb 9 11:43:27.251: ephone-108[107/92][SEP2C3F38C8B95F]:Call Info for chan 1
172802: Feb 9 11:43:27.251: ephone-108[107/92][SEP2C3F38C8B95F]:SkinnyDisplayCallInfo callingName=User7
172803: Feb 9 11:43:27.251: ephone-108[107/92]:SkinnyDisplayCallInfo No-calledName
172804: Feb 9 11:43:27.251: peer_vdb is NULL for DN 108, chan 1 at SkinnyIsPeerNonSCCP
172805: Feb 9 11:43:27.371: SkinnyGetMultiMediaCapabilities: dn: 108, chan: 1
172806: Feb 9 11:43:27.371: ephone-108[107/92][SEP2C3F38C8B95F]:SkinnyGetMultiMediaCapabilities: dn: 108, chan: 1
172807: Feb 9 11:43:27.471: SkinnyTransfereeHairpinRinging: dn 108 chan 1 tonetype 37
172808: Feb 9 11:43:27.471: dn_tone_control DN=108 chan 1 tonetype=37:DtReorderTone onoff=1 pid=309
172809: Feb 9 11:43:27.471: ephone-108[107/92][SEP2C3F38C8B95F]:DN 108 disc reason 28 invalid number state ALERTING
172810: Feb 9 11:43:27.471: SkinnyGetCallState for DN 108 chan 1 ALERTING
172811: Feb 9 11:43:27.471: called DN -1 chan 1, calling DN -1 chan 1 phone 108 s2s:0
172812: Feb 9 11:43:27.471: SkinnyGetCallState for DN 108 chan 1 ALERTING
172813: Feb 9 11:43:27.471: called DN -1 chan 1, calling DN -1 chan 1 phone 108 s2s:0
172814: Feb 9 11:43:27.471: ephone-108[107/92][SEP2C3F38C8B95F]:is_auto_local 0 for DN 108
172815: Feb 9 11:43:27.471: ephone-108[107/92][SEP2C3F38C8B95F]:SkinnySetToneRef callRef
EDM-CUCME#
I have made one dial peer more specific so no more 9T and I can see that dial peer 99 is up
sh dial-peer voice 99
VoiceEncapPeer99
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `INT test',
        tag = 99, destination-pattern = `9011T',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 99, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):INTER_OUT
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        trunk-group:
        id = `PRI', preference = `'
        type = pots, prefix = `011',
        forward-digits default
        session-target = `', voice-port = `',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 11, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "1C  ",
        Last Disconnect Text is "invalid number (28)",
        Last Setup Time = 164970668.
        Last Disconnect Time = 0.
Green
Alex
It dd end up being thr TON in addition had to make the change to my s0/0/0:23
isdn map address ^011* plan unknown type unknown
thank you all this was great .
1395
