Trouble with my T1's and E1's in the lab - please help.... :-)
I'm working through my CCIE Voice/Collaboration training materials and am just about finished with the physical construction of the lab.  At this time I'm just going to install a new T1 card into my BR1 router and I'm trying to get my T1 to HQ (HQ router) and my E1 to BR2 (Branch2 router) up and running.  I am enclosing the "show run", "show isdn status" and "show e1/t1 controller" outputs.  I am using a 2801 for my HQ router, a 2851 for my PSTN/IP-WAN router, and a 2811 for my BR2 router.
I am using a T1 cable RJ-48C/RJ-48C.  I'm embarassed to say it - but I don't have a cable tester at the time.  I lended my backup out to a friend and my primary one is not working.  I'm also not 100% sure that I'm using the correct cable.  I have VWIC2-2MFT-T1/E1 cards in my routers and I have a 2851 (PSTN router) setup to give connectivity via the T1's to HQ and BR1 and E1 connectivity to BR2.  I have taken the liberty of attaching my configs, as mentioned I don't think I have cable issues because this is the case with all my cables.
Main issue, in the "show isdn stat" the layer 1 status is "deactivated" and when I do a shut/no shut the status goes to "shutdown" and doesn't come back up despite my efforts to enable the interface.  The only way to fix it is to reboot the router.  I've got to be missing something - I just want to get my T1's and E1 up for my CCIE Lab.  I'm building my lab based on the CCIE Voice specification and have the ability to get it modified eventually to fit the CCIE Collaboration lab.
***PLEASE go easy on me - I'm sure there is a fundamental configuration item or concept I'm not thinking about so I'm preparing to look like a fool - but that's okay....it's part of learning.  :-)  ***
Any help would be so much appreciated.  All configs are pasted below.......
=================START OF BR2 CONFIG=======================
BR2_RTR#show controllers e1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (895 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 895 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
BR2_RTR#show isdn stat
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
    Total Allocated ISDN CCBs = 0
BR2_RTR#show inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V06 , SN: FTX1328A0D3
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC11271UAU
NAME: "WAN Interface Card - Serial 2T on Slot 0 SubSlot 1", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T            , VID: V01, SN: 35759031
NAME: "PVDMII DSP SIMM with three DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48          , VID: V01 , SN: FOC12221GJE
NAME: "AIM Service Engine 0", DESCR: "AIM Service Engine"
PID: AIM-CUE           , VID: V03 , SN: FOC11505K9D
NAME: "16 Port 10BaseT/100BaseTX EtherSwitch on Slot 1", DESCR: "16 Port 10BaseT/100BaseTX EtherSwitch"
PID: NM-16ESW=         , VID: 1.0, SN: FOC09245Q0H
NAME: "Power daughter card for 16 port EtherSwitch NM on Slot 1 SubSlot 0", DESCR: "Power daughter card for 16 port EtherSwitch NM"
PID:                     , VID: 1.0, SN: FOC09243VGH
NAME: "Gigabit(1000BaseT) module for EtherSwitch NM on Slot 1 SubSlot 1", DESCR: "Gigabit(1000BaseT) module for EtherSwitch NM"
PID:                     , VID: 1.0, SN: FOC092034R1
BR2_RTR#
BR2_RTR#
BR2_RTR#
BR2_RTR#
BR2_RTR#
BR2_RTR#show run
Building configuration...
Current configuration : 9148 bytes
! No configuration change since last restart
version 15.1
hostname BR2_RTR
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$kYuC$TYARPnIw8mjqiVM3CqM15.
no aaa new-model
clock timezone CET 1 0
clock summer-time CET recurring 1 Sun Apr 1:00 last Sun Oct 1:00
network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.30.1 192.168.30.49
ip dhcp excluded-address 192.168.30.70 192.168.30.254
ip dhcp pool PHONES
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
option 150 ip 3.3.3.3
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice service voip
allow-connections sip to sip
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice register global
mode cme
source-address 3.3.3.3 port 5060
max-dn 20
max-pool 10
load 7960-7940 P0S3-08-6-00
authenticate register
tftp-path flash:
create profile sync 1684632613172238
voice register dn  1
number 3005
name BR2_Phone3
voice register dn  2
number 3006
name BR2_Phone4
voice register template  1
no conference enable
voice register dialplan 1
type 7940-7960-others
pattern 1 3...
pattern 2 999
voice register pool  1
id mac 0008.E31B.7CD4
type 7960
number 1 dn 1
template 1
dtmf-relay sip-notify
username 3005 password cisco
description 3214-3005
codec g711ulaw
voice translation-rule 1
rule 1 /^\(3...$\)/ /3214\1/
voice translation-rule 2
rule 1 /^32143/ /3/
rule 2 /^\+3432143/ /3/
voice translation-rule 3000
rule 1 /^3000/ /1002/
voice translation-profile 3000
translate called 3000
voice translation-profile 4digitDNIS
translate called 2
voice translation-profile 8digitANI
translate calling 1
voice-card 0
license udi pid CISCO2811 sn FTX1328A0D3
redundancy
controller E1 0/0/0
pri-group timeslots 1-3,16
interface Loopback0
ip address 3.3.3.3 255.255.255.255
h323-gateway voip bind srcaddr 3.3.3.3
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Service-Engine0/0
no ip address
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.21
description BR2-PHONES(RTR on a stick)
encapsulation dot1Q 21
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/1.22
description BR2-DATA(RTR on a stick)
encapsulation dot1Q 22
ip address 192.168.31.1 255.255.255.0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn outgoing display-ie
no cdp enable
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
description BR2-RTR_IP-WAN
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0/1/1.1 point-to-point
ip address 10.1.1.2 255.255.255.128
frame-relay interface-dlci 301
interface FastEthernet1/0
description BR2-PHONE1
switchport mode trunk
switchport voice vlan 40
no ip address
spanning-tree portfast
interface FastEthernet1/1
description BR2-PHONE2
no ip address
interface FastEthernet1/2
no ip address
interface FastEthernet1/3
no ip address
interface FastEthernet1/4
no ip address
interface FastEthernet1/5
no ip address
interface FastEthernet1/6
no ip address
interface FastEthernet1/7
no ip address
interface FastEthernet1/8
no ip address
interface FastEthernet1/9
no ip address
interface FastEthernet1/10
no ip address
interface FastEthernet1/11
no ip address
interface FastEthernet1/12
no ip address
interface FastEthernet1/13
no ip address
interface FastEthernet1/14
no ip address
interface FastEthernet1/15
no ip address
interface GigabitEthernet1/0
no ip address
interface Vlan1
no ip address
interface Vlan30
description PHONES-VLAN-FOR-LAYER3-SWITCHING
no ip address
shutdown
interface Vlan31
description DATA-VLAN-FOR-LAYER3-SWITCHING
no ip address
shutdown
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
network 10.1.1.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
network 192.168.31.0 0.0.0.255 area 0
network 192.168.0.0 0.0.255.255 area 0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:/GUI
ip route 192.168.100.0 255.255.255.0 10.1.1.1
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:ringtones/Vibe.raw
tftp-server flash:PHONE/7940-7960/P0S3-08-6-00.loads alias P0S3-08-6-00.loads
tftp-server flash:PHONE/7940-7960/P0S3-08-6-00.sb2 alias P0S3-08-6-00.sb2
tftp-server flash:PHONE/7940-7960/P0S3-08-6-00.bin alias P0S3-08-6-00.bin
tftp-server flash:PHONE/7940-7960/P0S3-08-6-00.sbn alias P0S3-08-6-00.sbn
control-plane
voice-port 0/0/0:15
translation-profile outgoing 4digitDNIS
mgcp profile default
dial-peer voice 999 pots
translation-profile outgoing 8digitANI
destination-pattern 999
port 0/0/0:15
forward-digits 3
dial-peer voice 1 voip
incoming called-number .
dial-peer voice 901134 pots
destination-pattern 901134T
port 0/0/0:15
dial-peer voice 3000 voip
translation-profile outgoing 3000
destination-pattern 3000
session target ipv4:192.168.15.23
voice-class codec 1
voice-class h323 1
telephony-service
no auto-reg-ephone
max-ephones 10
max-dn 20
ip source-address 3.3.3.3 port 2000
network-locale ES
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name admin password cisco
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Jan 23 2014 05:43:52
ephone-template  1
softkeys connected  Hold Select Trnsfer Endcall HLog Park
ephone-dn  1
number 3001
name BR2_Phone1
ephone-dn  2
number 3002
name BR2_Phone2
ephone  1
device-security-mode none
description 3214-3001
mac-address 0008.A3FD.3A32
ephone-template 1
max-calls-per-button 5
busy-trigger-per-button 3
type 7960
button  1:1
ephone  2
description 3214-3002
mac-address 0017.E0C6.E232
ephone-template 1
type 7961
button  1:2
banner motd ^CBR2 ROUTER CUCME/CUE^C
line con 0
password cisco
logging synchronous
login
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp server 172.30.1.2
end
===========END OF BR2 CONFIG=================
===========START OF HQ CONFIG================
HQ-RTR#show inventory
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801         , VID: V02 , SN: FTX1016Y07Z
NAME: "motherboard", DESCR: "C2801 Motherboard with 2 Fast Ethernet"
PID: CISCO2801         , VID: V02 , SN: FOC10140N6M
NAME: "WIC/VIC 2", DESCR: "Two port T1 voice interface daughtercard"
PID: VWIC-2MFT-T1=     , VID: 1.0, SN: 32867042
NAME: "WIC/VIC/HWIC 3", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T=           , VID: 1.0, SN: 32195023
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with three DSPs"
PID: PVDM2-48          , VID: V01 , SN: FOC132935YB
HQ-RTR#
HQ-RTR#show controllers t1
T1 0/2/0 is down.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (709 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 709 Unavail Secs
T1 0/2/1 is down.
HQ-RTR#show isdn stat
Global ISDN Switchtype = primary-ni
ISDN Serial0/2/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
HQ-RTR#
HQ-RTR#show run
Current configuration : 6734 bytes
! Last configuration change at 02:32:03 UTC Tue Feb 4 2014
version 15.1
hostname HQ-RTR
boot-start-marker
boot-end-marker
logging buffered 512000 informational
enable secret 5 $1$K8GP$JbYRetpgnaxvy2wnjrPDW/
no aaa new-model
network-clock-participate wic 2
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.11.1 192.168.11.10
ip dhcp excluded-address 192.168.12.1 192.168.12.10
ip dhcp excluded-address 192.168.13.1 192.168.13.10
ip dhcp excluded-address 192.168.14.1 192.168.14.10
ip dhcp excluded-address 192.168.16.1 192.168.16.10
ip dhcp excluded-address 192.168.17.1 192.168.17.10
ip dhcp pool HQ-BR1-Pool
import all
network 192.168.11.0 255.255.255.0
option 150 ip 10.10.210.10
default-router 192.168.11.1
domain-name proctorlabs.com
dns-server 8.8.4.4 8.8.8.8
lease 8
ip dhcp pool BR2-Pool
import all
network 192.168.12.0 255.255.255.0
option 150 ip 10.10.202.1
default-router 192.168.12.1
lease 8
ip dhcp pool PSTN-Pool
import all
network 192.168.13.0 255.255.255.0
option 150 ip 10.10.100.2
default-router 192.168.13.1
lease 8
ip dhcp pool Laptop-Pool
import all
network 192.168.14.0 255.255.255.0
default-router 192.168.14.1
lease 8
ip dhcp pool WIRELESS-HOME
import all
network 192.168.16.0 255.255.255.0
default-router 192.168.16.1
dns-server 8.8.8.8 4.2.2.2
lease 8
ip cef
no ip domain lookup
ip domain name proctorlabs.com
no ipv6 cef
isdn switch-type primary-ni
voice service voip
sip
voice class codec 1
voice-card 0
license udi pid CISCO2801 sn FTX1016Y07Z
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24
controller T1 0/2/1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
description (Outside Public Interface)
ip address dhcp
ip access-group FW-IN in
no ip unreachables
ip mtu 1300
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
no ip address
duplex auto
speed auto
interface FastEthernet0/1.11
description (Inside Private Interface)
encapsulation dot1Q 11
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.12
encapsulation dot1Q 12
ip address 192.168.12.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.13
encapsulation dot1Q 13
ip address 192.168.13.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.14
encapsulation dot1Q 14
ip address 192.168.14.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.15
description LAB-SERVERS
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.16
description WIRELESS-HOME
encapsulation dot1Q 16
ip address 192.168.16.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.17
description LAB-HQ-PHONES
encapsulation dot1Q 17
ip address 192.168.17.1 255.255.255.0
ip helper-address 192.168.15.22
ip nat inside
interface FastEthernet0/1.18
description LAB-HQ-DATA
encapsulation dot1Q 18
ip address 192.168.18.1 255.255.255.0
ip nat inside
interface FastEthernet0/1.501
description PSTN-RTR_MGMT-NETWORK
encapsulation dot1Q 501
ip address 172.30.1.1 255.255.255.0
ip nat inside
interface Serial0/2/0:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/3/0
description HQ-RTR_IP-WAN
no ip address
no fair-queue
interface Serial0/3/0.1 point-to-point
ip address 10.1.1.1 255.255.255.128
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 103
interface Serial0/3/0.2 point-to-point
ip address 10.1.1.129 255.255.255.128
ip ospf mtu-ignore
frame-relay interface-dlci 102
interface Serial0/3/1
no ip address
shutdown
clock rate 2000000
router ospf 1
network 1.1.1.1 0.0.0.0 area 0
network 172.30.1.0 0.0.0.3 area 0
no ip http server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.1 254
ip route 192.168.100.0 255.255.255.0 172.30.1.2
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 101 deny   ip 192.168.0.0 0.0.255.255 10.10.0.0 0.0.255.255
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
access-list 102 permit udp any any eq bootps
access-list 102 permit udp any any eq bootpc
access-list 102 permit udp any eq bootpc any
access-list 102 permit udp any eq bootps any
disable-eadi
control-plane
voice-port 0/2/0:23
mgcp fax t38 ecm
dial-peer voice 91212 pots
description PSTN-CALLS-TO-NYC-AREA-CODE
destination-pattern 91212T
port 0/2/0:23
forward-digits all
dial-peer voice 1 pots
description INCOMING-DIAL-PEER_PSTN
direct-inward-dial
port 0/2/0:23
dial-peer voice 1000 voip
destination-pattern 2123941...
session protocol sipv2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1001 voip
preference 1
session target ipv4:192.168.15.22
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
retry invite 2
timers trying 300
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
password cisco
logging synchronous
login
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
password cisco
logging synchronous
login
end
HQ-RTR#
=============END OF HQ CONFIG=============
=======START OF PSTN-IP-WAN_RTR CONFIG=========
PSTN_IP-WAN_RTR#show inventory
NAME: "2851 chassis", DESCR: "2851 chassis"
PID: CISCO2851         , VID: V01 , SN: FTX0922A1E7
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN: FOC11063UF9
PID: WIC-2T      , VID: V01, SN: 35845606
NAME: "Two port T1 voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "Two port T1 voice interface daughtercard"
PID: VWIC-2MFT-T1=     , VID: 1.0, SN: 29803060
NAME: "WAN Interface Card - Serial 2T on Slot 0 SubSlot 3", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T=           , VID: 1.0, SN: 23188546
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC12045356
PSTN_IP-WAN_RTR#show controllers t1
T1 0/2/0 is down.
  Description: HQ_T1
  Version info Firmware: 20071129, FPGA: 20, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  Data in current interval (852 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 852 Unavail Secs
T1 0/2/1 is down.
  Description: BR1_T1
  Data in current interval (854 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 854 Unavail Secs
PSTN_IP-WAN_RTR#show controllers e1
E1 0/0/0 is down.
  Cablelength is Unknown
  Description: BR2_E1
  Version info Firmware: 20071011, FPGA: 13, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (862 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 862 Unavail Secs
E1 0/0/1 is down.
  Data in current interval (864 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 864 Unavail Secs
PSTN_IP-WAN_RTR#
PSTN_IP-WAN_RTR#
PSTN_IP-WAN_RTR#show isdn status
        ******* Network side configuration *******
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
ISDN Serial0/0/1:15 interface
        dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
        dsl 2, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 2 CCBs = 0
ISDN Serial0/2/1:23 interface
        dsl 3, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 3 CCBs = 0
PSTN_IP-WAN_RTR#
PSTN_IP-WAN_RTR#show run
Current configuration : 6518 bytes
! Last configuration change at 23:02:02 CST Tue Feb 4 2014
version 12.4
hostname PSTN_IP-WAN_RTR
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
enable secret 5 $1$rLlG$MPPST59p5rs0FfXu8OXp1.
no aaa new-model
clock timezone CST -6
clock summer-time CDT recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.100.1 192.168.100.10
ip dhcp pool PSTN-PHONE
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.1
   option 150 ip 192.168.100.1
no ip domain lookup
no ipv6 cef
frame-relay switching
rule 1 /^011\(.*\)/ /\1/
rule 2 /^1\(.*\)/ /&/
rule 3 /^00\(.*\)/ /\1/
rule 4 /^617\(.*\)/ /1&/
rule 5 /^212\(.*\)/ /1&/
rule 1 /^617/ /1&/
rule 2 /^212/ /1&/
rule 1 /^212/ /1&/
rule 2 /^34/ /&/
voice translation-rule 4
rule 1 /^617/ /1&/
rule 2 /^34/ /&/
voice translation-profile BR1-OUT
translate calling 3
voice translation-profile BR2-OUT
translate calling 2
voice translation-profile HQ-OUT
translate calling 4
voice translation-profile PSTN-IN
translate called 1
voice-card 0
archive
log config
  hidekeys
controller E1 0/0/0
clock source internal
description BR2_E1
controller E1 0/0/1
controller T1 0/2/0
description HQ_T1
controller T1 0/2/1
description BR1_T1
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.13
description PSTN-PHONE_LAN
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/1
description MGMT-CONNECTION-via-WIFI
ip address 172.30.1.2 255.255.255.0
duplex auto
speed auto
description BR2-PSTN-CONNECTION
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
description FR_to_BR2-RTR
no ip address
clock rate 64000
frame-relay intf-type dce
frame-relay route 301 interface Serial0/3/0 103
no ip address
shutdown
clock rate 2000000
description HQ-PSTN-CONNECTION
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/2/1:23
no ip address
encapsulation hdlc
no cdp enable
description FR_to_HQ-RTR_point-to-point-BR1andBR2
no ip address
clock rate 64000
frame-relay route 102 interface Serial0/3/1 201
frame-relay route 103 interface Serial0/1/0 301
description FR_to_BR1-RTR-to-HQ-RTR
no ip address
frame-relay route 201 interface Serial0/3/0 102
ip route 1.1.1.1 255.255.255.255 172.30.1.1
ip route 2.2.2.2 255.255.255.255 172.30.1.1
ip route 3.3.3.3 255.255.255.255 172.30.1.1
ip route 10.1.1.0 255.255.255.0 172.30.1.1
ip route 192.168.14.0 255.255.255.0 172.30.1.1
ip route 192.168.15.0 255.255.255.0 172.30.1.1
ip route 192.168.16.0 255.255.255.0 172.30.1.1
ip route 192.168.17.0 255.255.255.0 172.30.1.1
ip route 192.168.20.0 255.255.255.0 172.30.1.1
ip route 192.168.21.0 255.255.255.0 172.30.1.1
ip route 192.168.30.0 255.255.255.0 172.30.1.1
ip route 192.168.31.0 255.255.255.0 172.30.1.1
no ip http server
tftp-server flash:P0030801SR02.bin
tftp-server flash:P0030801SR02.loads
tftp-server flash:P0030801SR02.sb2
tftp-server flash:P0030801SR02.sbn
tftp-server P0030801SR02.txt
control-plane
voice-port 0/0/0:15
voice-port 0/2/0:23
voice-port 0/0/1:15
voice-port 0/2/1:23
ccm-manager fax protocol cisco
mgcp fax t38 ecm
direct-inward-dial
dial-peer voice 10 pots
description HQ-NATIONAL-CALLS-DIAL-PEER
port 0/2/0:23
forward-digits all
dial-peer voice 20 pots
description BR1-NATIONAL-CALLS-DIAL-PEER
destination-pattern 6178632...
port 0/2/1:23
forward-digits all
dial-peer voice 30 pots
description BR2-NATIONAL-CALLS-DIAL-PEER
destination-pattern 32143...
port 0/0/0:15
forward-digits all
dial-peer voice 31 pots
description BR2-INTL-CALLS-DIAL-PEER
destination-pattern 3432143...
port 0/0/0:15
forward-digits all
telephony-service
em logout 0:0 0:0 0:0
max-ephones 2
max-dn 10
ip source-address 192.168.100.1 port 2000
load 7960-7940 P00303020214
keepalive 10
max-conferences 4 gain -6
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
number 12123945001
label +8087812321
description NYC
name NYC-PSTN
ephone-dn  2
number 16178635001
label 911+999
description BOSTON
name BOSTON-PSTN
ephone-dn  3
number 32145001
label 18005551234
description SPAIN
name SPAIN-PSTN
ephone-dn  4
number 3432145002
description SPAIN
name SPAIN-PSTN-INTL
ephone-dn  5
number 5005
label 7812321
description 7812321
ephone-dn  6
number 5006
label x5005
description OFFICE PHONE
ephone  1
mac-address 0008.A3FD.39FF
type 7960
button  1:1 2:2 3:3 4:4
button  5:5
banner motd ^CC PSTN-IP-WAN ROUTER ^C
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
ntp master
end
PSTN_IP-WAN_RTR#
Re: Trouble with my T1's and E1's in the lab - please help.... :
T1 to T1 requires a T1 crossover cable.  You can make them yourself, or buy them on ebay for about $5 each.  That is what I did for my Collaboration lab.  If you arent getting layer 1 up then its the cable.
VIP Purple
Hi Eric ,
you can refer the discussion on Cable details.
https://supportforums.cisco.com/message/4077414#4077414
regds,
aman
Have you no shut the voice ports?
Example:
(config)#voice-port 0/0/0:23 or 0/0/0:15
(config-if)#no shut
Yosh
HTH Regards, Yosh
I have went ahead and re-enabled the voice-ports just because I left that out of my original output.  See below.....
Do you think I ordered 3 factory made T1 cables from BlackBox and ALL of them came back to me bad?  Or perhaps they might not have made them as cross over cables......hmm...any other suggestions?
BR2_RTR(config)#voice-port 0/0/0:15
BR2_RTR(config-voiceport)#no shut
BR2_RTR(config-voiceport)#do sh voice port summ
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:15        01  isdn-voice  up    down none     none     y
0/0/0:15        02  isdn-voice  up    down none     none     y
0/0/0:15        03  isdn-voice  up    down none     none     y
50/0/1          1      efxs     up    dorm on-hook  idle     y
50/0/2          1      efxs     up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
HQ-RTR(config)#voice-port 0/2/0:23
HQ-RTR(config-voiceport)#no shut
HQ-RTR(config-voiceport)#do sh voice port summ
                                           IN       OUT
0/2/0:23        01  isdn-voice  up    down none     none     y
0/2/0:23        02  isdn-voice  up    down none     none     y
0/2/0:23        03  isdn-voice  up    down none     none     y
PSTN_IP-WAN_RTR#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
PSTN_IP-WAN_RTR(config)#voice-p
PSTN_IP-WAN_RTR(config)#voice-port 0/0/0:15
PSTN_IP-WAN_RTR(config-voiceport)#no shut
PSTN_IP-WAN_RTR(config-voiceport)#exit
PSTN_IP-WAN_RTR(config)#voice-port 0/2/0:23
PSTN_IP-WAN_RTR(config)#voice-port 0/0/1:15
PSTN_IP-WAN_RTR(config)#voice-port 0/2/1:23
PSTN_IP-WAN_RTR(config)#do sh voice port summ
                                           IN       OUT
0/0/0:15        01  isdn-voice  up    dorm none     none     y
0/0/0:15        02  isdn-voice  up    dorm none     none     y
0/0/0:15        03  isdn-voice  up    dorm none     none     y
0/2/0:23        01  isdn-voice  up    dorm none     none     y
0/2/0:23        02  isdn-voice  up    dorm none     none     y
0/2/0:23        03  isdn-voice  up    dorm none     none     y
0/0/1:15        01  isdn-voice  up    dorm none     none     y
0/0/1:15        02  isdn-voice  up    dorm none     none     y
0/0/1:15        03  isdn-voice  up    dorm none     none     y
0/2/1:23        01  isdn-voice  up    dorm none     none     y
0/2/1:23        02  isdn-voice  up    dorm none     none     y
0/2/1:23        03  isdn-voice  up    dorm none     none     y
50/0/3          1      efxs     up    dorm on-hook  idle     y
50/0/4          1      efxs     up    dorm on-hook  idle     y
50/0/5          1      efxs     up    dorm on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
VIP Purple
Hi Eric,
If you have spare factory crimped straight cable and rochett box , you can cut the cable from middle with RJ-45 connectors at both ends and cross it 1,2 and 4,5 on rochett box and check further.
regds,
aman
VIP Super Bronze
You are missing the network-clock-select command from all your gateways..
e.g on PSTN gateway
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 T1 0/2/0
Please apply it using the different interfaces you want to select clocking from...
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The network clock select must be entered only for thr e1 and t1 controllers on the PSTN router or on the HQ and branch routers too?
VIP Super Bronze
Each router needs to know where its going to get its clocking from. This command tells it where to get it from. So all your gateways need it
472
СоздатьДля создания публикации, пожалуйста в систему
