Community Member
Troubles in resetting Cisco IP phones after upgrading a SIP Firmware to it
Hello everyone ...!
As i am trying to upload SIP firmware on Cisco IP 7940 Series but unfortunately getting Messages like "UNPROVISIONED SIP" & "UNPROVISIONED PHONE" on the sreen. after this I couldnt be able to do factory default reset to these phone . am attaching a image.Cnf file which am trying to upload  and the entire file which i used in TFTP root directory
# SIP Default Generic Configuration File
# Image Version
image_version: P0S3-8-12-00
# Proxy Server
proxy1_address: "10.6.14.53"  ; Can be dotted IP or FQDN
proxy2_address: ""  ; Can be dotted IP or FQDN
proxy3_address: ""  ; Can be dotted IP or FQDN
proxy4_address: ""  ; Can be dotted IP or FQDN
proxy5_address: ""  ; Can be dotted IP or FQDN
proxy6_address: ""  ; Can be dotted IP or FQDN
# Proxy Server Port (default - 5060)
proxy1_port: 5060
proxy2_port: 5060
proxy3_port: 5060
proxy4_port: 5060
proxy5_port: 5060
proxy6_port: 5060
# Proxy Registration (0-disable (default), 1-enable)
proxy_register: 1
# Phone Registration Expiration [1-3932100 sec] (Default - 3600)
timer_register_expires: 3600
# Codec for media stream (g711ulaw (default), g711alaw, g729a)
preferred_codec: g711ulaw
# TOS bits in media stream [0-5] (Default - 5)
tos_media: 5
# Inband DTMF Settings (0-disable, 1-enable (default))
dtmf_inband: 1
# Out of band DTMF Settings (none-disable, avt-avt enable (default), avt_always - always avt )
dtmf_outofband: none
# DTMF dB Level Settings (1-6dB down, 2-3db down, 3-nominal (default), 4-3db up, 5-6dB up)
dtmf_db_level: 3
# SIP Timers
timer_t1: 500    ; Default 500 msec
timer_t2: 4000    ; Default 4 sec
sip_retx: 10   ; Default 10
sip_invite_retx: 6   ; Default 6
timer_invite_expires: 180  ; Default 180 sec
####### New Parameters added in Release 2.0 #######
# Dialplan template (.xml format file relative to the TFTP root directory)
dial_template: dialplan
# TFTP Phone Specific Configuration File Directory
tftp_cfg_dir: ""  ; Example:  ./sip_phone/
# Time Server (There are multiple values and configurations refer to Admin Guide for Specifics)
sntp_server: ""   ; SNTP Server IP Address
sntp_mode: directedbroadcast ; unicast, multicast, anycast, or directedbroadcast (default)
time_zone: EST   ; Time Zone Phone is in
dst_offset: 1   ; Offset from Phone's time when DST is in effect
dst_start_month: April  ; Month in which DST starts
dst_start_day: ""  ; Day of month in which DST starts
dst_start_day_of_week: Sun ; Day of week in which DST starts
dst_start_week_of_month: 1 ; Week of month in which DST starts
dst_start_time: 02  ; Time of day in which DST starts
dst_stop_month: Oct  ; Month in which DST stops
dst_stop_day: ""  ; Day of month in which DST stops
dst_stop_day_of_week: Sunday ; Day of week in which DST stops
dst_stop_week_of_month: 8 ; Week of month in which DST stops 8=last week of month
dst_stop_time: 2  ; Time of day in which DST stops
dst_auto_adjust: 1  ; Enable(1-Default)/Disable(0) DST automatic adjustment
time_format_24hr: 1  ; Enable(1 - 24Hr Default)/Disable(0 - 12Hr)
# Do Not Disturb Control (0-off, 1-on, 2-off with no user control, 3-on with no user control)
dnd_control: 0   ; Default 0 (Do Not Disturb feature is off)
# Caller ID Blocking (0-disbaled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
callerid_blocking: 0  ; Default 0 (Disable sending all calls as anonymous)
# Anonymous Call Blocking (0-disabled, 1-enabled, 2-disabled no user control, 3-enabled no user control)
anonymous_call_block: 0  ; Default 0 (Disable blocking of anonymous calls)
# DTMF AVT Payload (Dynamic payload range for AVT tones - 96-127)
dtmf_avt_payload: 101  ; Default 101
# Sync value of the phone used for remote reset
sync: 1    ; Default 1
####### New Parameters added in Release 2.1 #######
# Backup Proxy Support
proxy_backup: ""  ; Dotted IP of Backup Proxy
proxy_backup_port: 5060  ; Backup Proxy port (default is 5060)
# Emergency Proxy Support
proxy_emergency: ""   ; Dotted IP of Emergency Proxy
proxy_emergency_port: 5060 ; Emergency Proxy port (default is 5060)
# Configurable VAD option
enable_vad: 0   ; VAD setting 0-disable (Default), 1-enable
####### New Parameters added in Release 2.2 ######
# NAT/Firewall Traversal
nat_enable: 0                   ; 0-Disabled (default), 1-Enabled
nat_address: ""          ; WAN IP address of NAT box (dotted IP or DNS A record only)
voip_control_port: 5060       ; UDP port used for SIP messages (default - 5060)
start_media_port: 16384  ; Start RTP range for media (default - 16384)
end_media_port: 32766    ; End RTP range for media (default - 32766)
nat_received_processing: 0 ; 0-Disabled (default), 1-Enabled
# Outbound Proxy Support
outbound_proxy: "10.6.14.53"   ; restricted to dotted IP or DNS A record only
outbound_proxy_port: 5060       ; default is 5060
####### New Parameter added in Release 3.0 #######
# Allow for the bridge on a 3way call to join remaining parties upon hangup
cnf_join_enable : 1  ; 0-Disabled, 1-Enabled (default)
####### New Parameters added in Release 3.1 #######
# Allow Transfer to be completed while target phone is still ringing
semi_attended_transfer: 1 ; 0-Disabled, 1-Enabled (default)
# Telnet Level (enable or disable the ability to telnet into the phone)
telnet_level: 0   ; 0-Disabled (default), 1-Enabled, 2-Privileged
####### New Parameters added in Release 4.0 #######
# XML URLs
services_url: "http://10.6.5.184/ciscoaddresssip/ciscosearch.xml"  ; URL for external Phone Services
directory_url: "http://10.6.5.184/ciscodirectorysip/ciscosearch.xml"  ; URL for external Directory location
logo_url: ""   ; URL for branding logo to be used on phone display
# HTTP Proxy Support
http_proxy_addr: ""  ; Address of HTTP Proxy server
http_proxy_port: 80  ; Port of HTTP Proxy Server (80-default)
# Dynamic DNS/TFTP Support
dyn_dns_addr_1: ""              ; restricted to dotted IP
dyn_dns_addr_2: ""              ; restricted to dotted IP
dyn_tftp_addr: ""               ; restricted to dotted IP
# Remote Party ID
remote_party_id: 0  ; 0-Disabled (default), 1-Enabled
####### New Parameters added in Release 4.4 #######
# Call Hold Ringback (0-off, 1-on, 2-off with no user control, 3-on with no user control)
call_hold_ringback: 0  ; Default 0 (Call Hold Ringback feature is off)
####### New Parameters added in Release 6.0 #######
# Dialtone Stutter for MWI
stutter_msg_waiting: 0  ; 0-Disabled (default), 1-Enabled
# RTP Call Statistics (SIP BYE/200 OK message exchange)
call_stats: 0   ; 0-Disabled (default), 1-Enabled
289
